 Hi All As it was my birthday last week [don't ask  ] I have had some treats come my way, the first being the Hold and Fold 5.5 [5 speed]  etch bending tool. This is the largest one you can buy and will replace my old smaller folder which was great until the parts were bigger than the old bender  . Made from aircraft grade aluminium with two spring loaded thumb nuts, it has a good weight to it and there are different sizes of fingers and raised areas to aid in bending etch parts. A folding tool is also provided to use with the bending patterns. Not a cheap tool to buy but its going to provide me with many years of service. regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice one “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Hi Jase Thanks for looking in Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Its far better device than the plastic alternatives, that tend not to provide a crisp edge.
Be carefull of the blades mate as they can take the hair off a gnats Ar** in the wrong hands!
 Hi Spencer Il keep that in mind and thanks for the tip regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
