Fine sanding kit Options
#1 Posted : 13 October 2013 11:24:11
Hi All,BigGrin
Found this Micro-Mesh craft kit on ebay.
It can be used on all sorts of materials and has a wide range of grit sizes in one kit.
Contents:
9 double sided pads
3 double sided finger files - giving six grades
1 bottle micro liquid + cloth
Hope you find this useful.
#2 Posted : 14 October 2013 16:17:24
thanks for the pics del.
#3 Posted : 14 October 2013 17:20:10
Thanks Del for the good infoBigGrin Kind regards Mike
#4 Posted : 14 October 2013 20:05:14
Might have to invest in one
Thanks for sharing
J
#5 Posted : 14 October 2013 20:38:38
def get those.
#6 Posted : 14 October 2013 20:55:28
Hi Guys,
Glad I could help out.BigGrin
The pads are only 2 inches square, but they are double sided and they reckon they last 20 times longer than other items for the same job.
There are other sellers on ebay that do larger pieces should you require them when replacements are needed.
I thought this was a good starter so you can see how it works.Cool
#7 Posted : 14 October 2013 20:57:54
do you think the pads can be easily cut down into narrow fingers for detail work?
#8 Posted : 14 October 2013 21:23:10
Hi Jase,BigGrin
The pads as I mentioned are only 2 inches square but the centre is of a foam construction with a thin abrasive layer either side, therefore I don`t see any reason why you should not be able to cut them if required.
The finger files supplied give you 6 of the 9 grades in the selection of pads.
Hope this helps.BigGrin
This page was generated in 0.854 seconds.
