mark 2 wrote:Hi Andy  . I very much look forward to your build as i too would like to do this ship at a later stage as at the moment i have to many things on the go and not enough wonga  . I would also  to do the spitfire at some stage too. I wish you the best of luck with your build. Best regards. Mark I have to agree with you Mark they are both fab models. “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Hi Mark Thanks for looking in and your comments, as I have mentioned before there's lots of temptation on here at the moment and sometimes funds wont streach to all you would like regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Here we go, I received the first 5 issues this week and have been cracking on with her, I have made up a dry dock using brackets and wooden retainers as you will see from the pic's. So here's work in progress most of the hull components have been fitted together now and the 1st deck has been planked as per the instructions, my only deviation here was to use cocktail sticks for the trenail's instead of the pencil marking. More soon regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Fantastic, one of my most favorite ships! I have been wanting to start this subscription for a while now. Hopefully, as this is an Occre based kit the gun ports are pre-cut and the frames and port lids are metal fitting so will save loads of time  Good luck with this, Im sure you will do a fantastic job, BTW are you painting or leaving natural? Steve
Indeed Steve, gunports pre-cut, linings and lids are cast metal.
Nice start Andy
 Hi Steve Thanks for looking in and your comments, she has loads of metal parts as you say and has lots of different hard woods in her construction a full set of sails and an X -section like the Victory to boot. I have been itching to start this one regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Tom Thanks for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 24/02/2013 Posts: 212 Points: 632 Location: denmark
Hi arpurchase Follow with interest . and wish you good louck on your build Cheers SAMSON
 Hi Samson Thank you for looking in and your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All This months issue is all done now, added the 2nd set of cross beams planked and trenailed the deck and added the planks to the front section, now its just awaiting more parts regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy, great start you have made on this one...  .. I have up to part 25 now in my collection and reading through the download instructions I see we are to build the cross section in tandem with the main build rather than at the end, think this will make the build a little more interesting.....  .. Keep posting, look forward to you next instalment.. Regards Alan
Nice to see you have made a start Andy  looking forward to following your log along. Kind Regards Nigel
 Hi Alan Thanks for looking in and your comments, interesting about the X-Section I may just save the parts and do at the end like the vic regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Nigel Glad to be started not much going on at 1st though thanks for your comments regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All More progress, all the false keel now fitted and the false deck is in situ aswell. The lower deck is now fitted and has been planked ready for the trenails. More soon Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy you are making good progress  looks great Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Looking great nice decking. It's a great looking kit J “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Hi Mike Thanks for your comments and looking in regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Jase thanks for looking in, the deck im doing now will disappear under another deck soon and the only part visible will be the welldeck part but as its hard to get at the details make the difference. I will shortly be starting on the x-section regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy. Great job and looking forward to more updates  . Best regards. Mark
Guest (18)
