 Rank: Vice-Master        Groups: Registered
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Hi! Perfect work, I like it! Regards, Bernd
Thankyou for the comments! Just a small update - I had to go back to a previous issue to clear up a few bits i left out until the stern was complete. The main job being the 20 gun ports to have lids and doors fitted. These are done at this stage as they will be hard to get to later in the build when the shrouds are in place. I under-estimated the amount of work involved in these but they do take a long time. On to the forcastle timber heads now Steve stevie_o attached the following image(s):
Joined: 01/04/2013 Posts: 342 Points: 1,029 Location: Essex
Nice work Steve. Regards Alan England expects that every man will do his duty.
Hi Steve, Lovely work there, all looking really good. Keep up the good work. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 24/02/2013 Posts: 212 Points: 632 Location: denmark
Hi Stevie Its a buatiful model and so true to the real vic in details -- Love it . Cheers SAMSON.
Beautiful work Stevie, well worthy of a yellow medal..... Simply love it.... Regards Alan
Looking good Steve  Kind Regards Nigel
Thanks all for the support, I have just cut and shaped 34 timberheads for the forcastle railing, hope to have some more pics soon Steve
Hi Steve. Great job on the gun port lids. Look forward to seeing more. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Looking great Steve  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Thankyou for your support Mike and Ian, much appreciated Steve
Beautiful finish Steveie. A lovely build could be ruined by poor paintwork, well done.
After tidying up the gun port lids and stern I have now started issue 84 proper as the other jobs were from earlier issues that id set aside. Next up was the forcastle timberheads and rails. The instructions say to drill 3mm holes which are then carved into squares to receive the timberheads, I used the sandwich method instead which is detailed below, so rather than a single 6x2mm strip I used instead a 3mm and a couple of 2mm each side, this then gave 7mm width so i sanded .5mm off each side at the end.The advantage here was that the timberheads were all perfectly in line and there were no oversize holes so kept it all much neater. More later... stevie_o attached the following image(s):
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Nice work Steve  your Build looks great
Thanks for looking Peter
Fab work Steve, nice way to build up the timberheads and rails.. will bank that idea for later use.... Regards Alan
Nicely done Steve Regards Alan England expects that every man will do his duty.
Thankyou Alan...and Alan Im currently building and rigging another 6 guns for the quarter deck, will have some pics tomorrow. Cheers Steve
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
HI Steve
Cracking build you have there. Look forward to your progress.
Foz
Thankyou Foz, Here are some more pics of whats been done in the last couple of days. Firstly the timberhead rails were added, all pretty much as per instructions except for the build method mentioned in previous post. stevie_o attached the following image(s):
Guest (16)
