8 Pages «<23456>»
Moebius 1/32 Flying Sub Diary Options
claret
#61 Posted : 11 October 2013 08:32:47
Hi Andy,
Thanks for the tip. Not heard of these, so will have a look into it.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
claret
#62 Posted : 14 October 2013 08:43:44
Hi andy,
bottle of micro sol on order, due for delivery today/tomorrow.
Many thanks.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#63 Posted : 14 October 2013 08:52:48
Hi,
a bit more progress, a say a bit, not much to show but it was a few hours work.
To access the bunk bed of above the cupboards, PE foot steps are available in the PE kit. I gut these these out and filled the tabs off.
The long thin parts have three bends in, which were bent ensuring the right side and directions were executed.
the parts were cleaned with acetone nail polish remover and triangular supports were super glued into place.
As I had previously removed two cupboard doors, I fabricated a walled cupboard for the hole out of 2mm styrene, glued the steps into place and gave the whole assembly a coat of grey primer. The wooden blocks are for support and will not be seen once the assembly is glued into place.
Thats all for now.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#64 Posted : 14 October 2013 13:37:08
Hi,
more progress with sanding down and cutting out plastic for the instrument panel walls and fitting PE.
The 'reactor' wall with PE in place.
Also one side of the instrumental panel walls fitted with PE and the other side not started as a comparison.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#65 Posted : 14 October 2013 13:45:09
Hi All,
Finally for now the bulk head walls and bunk bed and cupboards were primed and them airbrushed Tamiya dark sea grey.
The bunk bed walls above the cupboards, the flat area around the reactor round windows and sides of the other bulk heads are to be painted a lighter grey.
The storage area between the cupboards is dry fitted only. I have some 1mm brass rod on order to fit a coat rail.
Thats all for now.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#66 Posted : 14 October 2013 16:05:59
brilliant paint job,well done.
claret
#67 Posted : 15 October 2013 08:38:39
Thanks Karl.
getting used to airbrushing now and really enjoying it.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#68 Posted : 15 October 2013 08:46:49
Hi All,
Update on my progress.
Found that the ladder in its stowed position, did not have any support at the top of the ladder. PE bracket fitted that supported the base, as shpwn in the photo's.
Checking stills from the DVD, there is support for the ladder at the top. I duly drilled holes in the ladder side, the circular top frame structure and used staples to act as the hinged supports. Looks much better now.
I have cleaned and primed the two fire extinguishers supplied with the kit, but looking at stills from the DVD, they are no where to be seen. Not decided to fit them now or not.
Thats all for now.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
Foz
#69 Posted : 15 October 2013 11:42:03
Doing a fantastic job there Claret. Looking forward to your progress.
Foz
claret
#70 Posted : 15 October 2013 12:53:29
Thanks for looking in Foz and commenting.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#71 Posted : 15 October 2013 15:07:04
Hi claret.
Great looking build. Look forward to seeing your progress ian Cool BigGrin
benny b
#72 Posted : 15 October 2013 20:14:28
she looks great claret keep up the great work benny.
#73 Posted : 15 October 2013 21:31:06
Coming along very very nicely Claret, love the paint job.....Cool
#74 Posted : 15 October 2013 23:22:54
not sure if you have seen this?
http://www.culttvmanshop...om-Night-Owl_p_1005.html
#75 Posted : 16 October 2013 00:10:49
claret
#76 Posted : 16 October 2013 08:55:05
Hi, Ian, Benny, Alan & Steve,
Many thanks for looking in and your comments.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#77 Posted : 16 October 2013 08:57:05
Hi Jase,
Yes I have been on this website, thanks.
This version of model is readily available and is the little brother of the 1/32 scale model I am doing.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#78 Posted : 20 October 2013 20:40:55
Hi All,
I finished painting the fire extinguishers in matt red, black and aluminium.
Painted a few parts which I will post tomorrow.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#79 Posted : 20 October 2013 21:10:03
Now that's nice painting Claret, well done.... Cool Cool .. Will be looking for your post tomorrow....Cool Cool
claret
#80 Posted : 21 October 2013 08:35:42
Hi Alan,
Many thanks.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
8 Pages «<23456>»
This page was generated in 0.178 seconds.
