Joined: 13/04/2013 Posts: 13 Points: 39 Location: Mansfield
I have built up the rear and attached it to the chassis plate, i tried putting wheels on just to have a look at the size and the wheels aren't running straight, both are at an angle towards the centre of the car, is this right? Have i done something wrong? Or is it resolved later on?
Also im needing some more grease, any places where you can get it from? Cheers
if you adjust your pics to 800x600 they will show on the page. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
I have no idea how I do that? I'm using my iPad can it be done?
Can't be done on an iPad unless you set your camera to standard definition
Joined: 10/10/2010 Posts: 691 Points: 2,136 Location: Dorset
Here you are WBurke one photo adjusted to size If I can help somebody as I go along PS I got a pair of socks like those GilShapley attached the following image(s): Current Build:- [color=blue]Stash Avro Lancaster (Full Kit)plus some extra issues I picked up at a good price [color=blue]Built:- Norman Catapult by Mantua,Roman Catapult by Mantua,HMS Victory,HMS Victory XSection,Focker DB1,Bismark,English Carronade Titanic Lifeboat,American Civil War Gatling,Hummer,Sopwith Camel F1,Occre Jupiter ,OcCre Wagon, Latina Arab Dhow, Eaglemass Orrery OcCre Rogers 119 [color=red][color=red]RB7,OcCre Missippi River Boat, Model Airways Fokker DR1 OcCre London L>C>C 106 Ugears Scrambler, Ugears Hexapod Explorer UGears Off-Road Vehicle
At least they match! Thanks for uploading the photo. To me the wheels look wrong they are angled towards the centre of the car, dont know if they should or not.
If you take a look at the step 4 image on page 94, you will notice that the visible lower suspension arm is set angled inwards, therefore the toe-in angle appears to be intended as there is no adjustment to make on this.
Kyosho have confirmed that the rear wheel toe-in is as it should be and is not a defect or problem.
It is intentionally made this way as this angle is important for the car to drive straight or to make appropriate turns.
The method to make this angle depends on the manufacture, but for our Hummer, it is created by the rear lower suspension plate and the angle quite obvious for buggy/offroad cars like our Hummer.
