Cheers guys. Much appreciated. Here are my pics from tonight. I have finished one side with only 4 planks to go on the other. So Sanded this side and like the outcome. I tried the plastic nose up to the front to see how thin to sand the so there is minimal sanding on the second layer. Thanks. magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Hi Chris. Great to see you back on the case. I am also doing the hood and upto stage 76. Your planking looks fantastic but then what would you expect from a craftsman like yourself. Very best regards. Mark
Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Hi Magpie, First class planking. well done!! Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
Hi Chris. Looking very nice. Keep the pictures coming. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Lovely planking Chris, cracking looking build....
Cheers Guys, Here Is the latest set of pics, The first set are of the prow of the ship, I have been looking at various builds and cannot find any decent pics of this area. Even the instructions are not very informative in this area. I decided I would change the way it done to suit me and to get it to look more like the actual ship.
In pic 1 you can see the peice to be insalled and my mod on the rear of it.In pic 2, I have arowed the faults. the pic in the left if you look at the front you will se the indented are on the nose stops just before he point. but if you look at the actual prow it follows round the front to the other side. Also pic 2 with arrow, the indentation is way exaggerated also doesnt taper like this one. So i am going to shrink the indent by half a mill nearer to scale. Thanks Chris magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Looking good Chris.... Regards Alan
Hi Chris I covered the Bow section page 48 to 49 (from post 949 through 961) of my build diary  I hope this helps. Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Cheers Mike and Alan. cheers Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Here a few more pics, I have also fitted the from panel from ply ith a few modifications to make it the correct thickness. The scale thickness before was 40cm deep cutout, but looking at my books it is no where near that deep. I will have made mine scale thickness of 10cm/.5mm when it gets its final layer of planks in the recess..magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Nice work Chris
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Very nice Chris. Looking forward to your progress.
Foz
Hi all , Thanks Mr T and Foz. On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Hi Chris, now she really is starting to take shape.... well done.... Regards Alan
Cheers Alan for your nice comments. Here is my next update. I have now started the second layer of planks. Hopefully should have done in 2 weeks. Chris. magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Looking great Chris and regardless how long it takes I will look forward to seeing her progress... Regards Alan
Hi all, Thanks Alan. Here are the updated pictures of where i am at with the build. Most of the second planking is done now. Hope to have all done by sunday night. Lol. magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Hi Cris coming together nicely, planking looks great regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Guys, Here is a little update. I tried to finish the planking off before today. But football on sunday took over the day.. Lol. I have nearly finished my second layer of planks now, I should be done in a day or so.
Cheersmagpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Looking superb Chris, look forward to seeing the planking finished and this build progressing..... Regards Alan
Guest (6)
