building the corronade Options
turboman
#1 Posted : 29 June 2010 01:30:20
Rank: Beginner Level 3
hi all can anyone tell me do you have to trim the small nail that fits into the
brass piece on the canon
thanks turboman
#2 Posted : 29 June 2010 08:40:33
Use side cutters or the cutting part of pliers.
Mike Turpin
#3 Posted : 29 June 2010 09:47:42
I assume by 'the brass piece' you are referring to the pivot that the carronade barrel rests on. Many of us decided that the barrel is too high if you use the brass piece described in the instructions. I suggest that before you carry on, you might like to try using the search facility on the forum. Click on 'Search' above and then enter carronade as the search term and follow some of the links to see what fellow members have done.
Mike T
Boaz
#4 Posted : 29 June 2010 16:06:12
Made my trunnion out of Green stuff.Cool
bit fiddly but makes for a much more realistic look.
Bob
This page was generated in 0.422 seconds.
