Exhaust Pipes Options
dbartonjr
#1 Posted : 30 October 2013 23:01:14
Dear All,
I have a quick question. I've been reviewing various build diaries and I notice some people do not use the soft metal strip for the exhaust pipes. This is good as I did not receive them in shipment 13 and do not feel like waiting 4 weeks for a replacement shipment. I thought I could use strip styrene in its place. I remember someone using 2mm rods and then cut them in 1/2. Three questions: is my memory playing tricks on me, if not what would be the item number and finally when it was said 'cut in half' I assume that means cut from the diameter. Thanks for everyone's help.
Dan
Current Builds: Yamato
On the Bench: Akagi, USS Missouri
#2 Posted : 30 October 2013 23:08:51
BigGrin Hi Dan
It was my build that I used strip styrene to replace the ports, I used Evergreens rod and tube assortment item no/ 217 . Simply cut slightly oversize and split in half with a knife then trim to size and glue
dbartonjr
#3 Posted : 31 October 2013 15:53:02
Andy,
Thanks for the information. What tool did you use to cut the styrene in half? I can think of a few cutters just looking for advice.
Thanks again,
Dan
#4 Posted : 31 October 2013 21:59:26
BigGrin Hi Dan
All I used was the Persona single edge blades or sometimes called safety blades to cut the styrene its quite easy to cut
This page was generated in 0.252 seconds.
