Help! Missing Chainwale support bracket Options
#1 Posted : 04 November 2013 21:00:25
Hi
Does anyone out there have a spare chainwale support bracket - if you have fitted your chainwales and find you have a spare I would love it if you could post it my way, P+P covered of course.
They came with issues 72 and 82 (12 in each one) and 24 of them are required all together but I only have 23Cursing
They are the brass angled brackets with a nail hole in each end (painted black in the pic below).
Please PM me if you can help, I don't really want to call customer services yet as I am still waiting for a replacement issue 85!
#2 Posted : 04 November 2013 21:51:48
Hi Steve,Crying
I`m only up to part 23 in my build, but I have all parts so I checked for you to see if I can help.
OMG I`ve only got 18.
Can anyone confirm how many of these brackets are required as it don`t tell you how many are meant to be supplied.
Sorry Steve,
#3 Posted : 04 November 2013 22:28:41
Hi Steve, Confused
Following up on the above, when we discussed the fitting of the wales the other day and I posted a link to the expanded pictures, well I just revisited that link and it only shows 9 brackets on one side, so my ageing brain says we only need 18 for the two sides.
Could this be correct or are there more brackets supplied in future issues for other wales?
Happy Building, from a now confused old fool. LOL LOL
#4 Posted : 04 November 2013 23:22:33
Hi Derek,
There are actually 12 per side - 4 on the main, 3 on the fore and 3 on the mizzen plus there are 2 small separate chainwales with one bracket each, these are on the main and mizzen only. Im sure there wont be any more supplied as by the end of this issue (87) all the chainwales are to be fitted to the hull.
A couple of spares would be handy on this sort of thing just in case one or two go missingAngry
Cheers
#5 Posted : 04 November 2013 23:45:06
stevie_o wrote:
Hi Derek,
Cheers
Hi Steve,Crying
Oh Pooh
I got to source 6 of the little blighters then,or coddle something up with a bit of brass.
We`ll see, Blink
#6 Posted : 05 November 2013 00:05:11
You should get 10 in issue 72 and 8 in issues 82. so 18 in total. Thats from checking the Mag I haven't counted parts. I don't see any in issues after 82. If you don't want to wait for replacements you could make some from brass tube. just crimp the ends in a vice and drill a hole, but I would recommend doing them all that way or not at all.
#7 Posted : 05 November 2013 00:14:01
Hi Jase,BigGrin
Thanks for that info.
Now I got the 18 you stated, but steve is coming up with a required total of 24.
Not sure now where the confusion is, as to how many are actually required.
#8 Posted : 05 November 2013 00:17:58
delboy271155 wrote:
Hi Jase,BigGrin
I have already fitted 23 to the chainwales, I'm 1 short.
Here is a breakdown -
fore mast - 3 per side
mainmast - 4 per side plus 1 per side for the "mini" chainwale.
mizzen - 3 per side plus 1 per side for the "mini" chainwale.
Total 24
Confused Your trying to confuse me nowLOL
#9 Posted : 05 November 2013 00:18:01
delboy271155 wrote:
Hi Jase,BigGrin
Like I said I only did a quick count in the mags, like we all could. Karl has just let me know there are 24 so 24 it is.
#10 Posted : 05 November 2013 00:47:21
jase wrote:
delboy271155 wrote:
Hi Jase,BigGrin
Hi Jase,BigGrin
Thanks for your assistance, I did the check as you so rightly say and I`ve got the 18 parts you stated.
Appreciate the time you and Karl have taken and will now add a new skill to my ever increasing list.
Brass bashing Cool
#11 Posted : 05 November 2013 00:55:01
No Problem mate, give me a shout if you need any support on the 'brass bashing'
GilShapley
#12 Posted : 05 November 2013 09:03:10
I have finally completed the Victory and can confirm (After a visual check) you require 24 supports
They where provided as follows
Issue 72 10
Issue 75 6
Issue 82 8
Total 24
Current Build:-
#13 Posted : 05 November 2013 09:20:55
Issue 72 10
Issue 75 6
Issue 82 8
Total 24
Hi Gil,BigGrin
Many thanks for taking the time to clear that one up.
That`s saved me the job of brass bashing LOL
Unfortunately it don`t solve poor Steve`s problem of missing one Confused
#14 Posted : 05 November 2013 09:54:48
Crying Nope, had a good search last night and not turned up so I think I was short in one of the mags, but if you only recieve 24 then I doubt anyone will have a spare one. Thanks everyone though!
GilShapley
#15 Posted : 05 November 2013 11:16:17
Well you could always order up a copy of one of the Mags in which the original supports where included but as we all know the delivery times can be protracted
The other option as already stated is to make your own.
try this
Take a length of Round Brass rod ( I had some 1/16" in the garage)
Cut a length using one of the original supports as a guide. I would cut it longer than required. Flatten the ends, I used my lump hammer as an anvil and an ordinary hammer to beat the c*** out of the brass rod.
Once the ends are flat you can shape them using a file or a dremmil if you have one, drill the holes for the pins. Jobs a good one
It took me about 5 mins to produce one
Piccy attached. Note sure about the size as I do not have one to use as a guide
Best of luck
Current Build:-
#16 Posted : 05 November 2013 12:36:21
#17 Posted : 05 November 2013 14:08:09
All doneBigGrin I used brass wire / rod and found that with flat large pliers you can crush the ends a bit at a time.
The last pic shows the new piece in place (foreground) the rear one is an original for comparison.
Thanks all for your support.
#18 Posted : 05 November 2013 14:59:58
WTG Steve,Cool
That`s looking good.BigGrin
#19 Posted : 05 November 2013 16:32:40
Spot on BigGrin
J
This page was generated in 0.162 seconds.
