chainwales Options
cal
#1 Posted : 13 November 2013 19:36:59
hi everyone after completing issue 75 a while ago in now in 83 ive just noticed that the jig I made for the deadeyes, the mag says use an off cut of 5mm wood ive used 4mm is this going to cause me problems later on then fitting the chainwales
thanks cal
#2 Posted : 13 November 2013 21:02:10
Hi Cal
Although I'm not actually building the DeAg Victory I've had a quick look at the official build pages. If the jig you mean is the one to wire the deadeye up on, you may be all right or you might need to make an adjustment or two! Blink
If you have the chainwales wooden pieces, check the bottom loop of the brass wire to see if it will allow the deadeye to sit on the 'platform', if it does, no problem!
If it's too tight to allow that however you'll either have to re-do the brass wire on a 5mm jig or else, if you have a rotary tool with a ball headed grinding tool you could gently sculpt out a semi-circular depression at the bottom of each slot which would allow the brass loop to fit in place, this could be hidden with some edging strip around the chainwale once all the deadeyes are in place.
Best of luck, but if you do need extra brass wire there are some good cheap suppliers on e-bay (that's where I generally go for mine!)BigGrin
cal
#3 Posted : 14 November 2013 14:59:09
Ive got them together ok but does anything go through the loop as there isn't much sticking out on most of them
cal attached the following image(s):
#4 Posted : 14 November 2013 15:10:18
Have a look at the official build for 87/87
cal
#5 Posted : 14 November 2013 15:54:08
B$%£&KSCursing looks like im redoing the wire on the dead eyes thanks tomick glad ive noticed it now not later on only one set to redoMellow
This page was generated in 0.123 seconds.
