28 Pages «<1516171819>»
Colson's Millenium Falcon Build Options
#321 Posted : 21 February 2016 15:03:27
A beautiful model and a top paint finish on this one.
Hope you are great fun with this build.
dowbyhuz
#322 Posted : 21 February 2016 15:17:02
I'm on board with everyone else, Colson. Bravo.
BTW, are you going to address the (IMO) far too distinct battle-damage? I find the stark dark (rhyme intentional) jarring.
When I get there (and I won't even begin until I have every part; early 2017 I suspect), I'll want to define the depths of these gouges with lighter-than-black tones, as well as some in-scale slightly raised edges along the lengths of the gashes. (Some (much of the) factory placed damage I'll just putty over and disappear.)
My best,
Dave
colson
#323 Posted : 21 February 2016 19:48:38
My best,
Dave
No, agreed. I'm going to dull down the battle damage a bit around the edges anyway, to give it more depth in the center. I also felt it was a bit do just black. I'm still debating on also on the rear left damage grinding it out in the center a bit more actually to make if physically deeper. And possibly adding some putty around the edges to make some jaggedy bits more like the actual filming model. They really dug in there on the filming one. But again, not completely finished, but darn close.
colson
#324 Posted : 22 February 2016 00:18:04
So I did end up working on the damage to the starboard side of the Falcon today.
What I did for starters was use the dremel and deepen the gouge a bit and chop it up. I also added some of the pit marks to the ramp section like on the real model.
I then put putty on a toothpick and dabbed it on the edges and pulled up making jagged rough patches. Then deepened the center a bit more.
Then repainted. Some of the putty color comes through the paint, which is still accurate to the filming model and gives a bit more depth and damage look to me. Much closer looking now to the actual filming model.
A Thumbs
#325 Posted : 22 February 2016 00:24:15
Nice work, Colson. I might try something similar. Good to know it can be done while surrounded by a full paint job. Now I just need a Dremel!
Taz
#326 Posted : 22 February 2016 07:06:30
Hi colson
This definitely looks more realistic, excellent work BigGrin
dowbyhuz
#327 Posted : 22 February 2016 13:33:45
Great, Colson! This is just what I had in mind. Your images are now officially part of my reference file! :)
My best,
Dave
LrdSatyr8
#328 Posted : 22 February 2016 21:24:02
Very nicely done bro! I really like the effect!
Fergazoid
#329 Posted : 29 February 2016 01:47:16
Hi Colson!
I'm greatly enjoying your build updates and following much of your lead, especially regarding lighting. I'm only thru about issue 9 myself so I have a question from further back. On your post #29 you show adding fiber optic filaments to the rear (arch) instrument panel. I'm wondering, given the very tight clearance between the panel and the hull, how you routed the filaments. It seems a near right-angle bend in the filaments would be required, whether you routed them straight past the back wall or down and along the curve of the hull and then back. I admit I haven't tried yet. So did that 90 degree bend work or did you find another way?! Any securing of those filaments on the back side would also have to be neatly done as well, I suspect.
colson
#330 Posted : 29 February 2016 04:08:31
Fergazoid wrote:
Hi Colson!
It was tricky. They bend pretty well. I didn't do a full 90, it's more an arch, but I laid them down flat and taped them to the wall. I have seen tricks online of using a lighter close to the filament to heat it up and it bends 90 degrees. Since I was able to get it to work the way I did, I never tried that. My 1.5mm fibers I'm using for the exterior red running lights pretty easily bend 90 degrees.
Fergazoid
#331 Posted : 02 March 2016 06:16:23
Thanks -- they do bend quite easily. I fastened them to their holes with a slight amount of Bondic and used more sparingly here and there to tack them down neatly and out of the way. (I hope.) That Bondic is great stuff!
colson
#332 Posted : 12 March 2016 01:33:20
BigGrin Kinda Funny. You can tell now, by the lack of posting for a week, that most people are about at the same point now in the build. There's really nothing to update anymore. Until we get towards having the whole upper section, I can see that posting will be a bit more quiet around the boards. I'm currently working on my Bandai AT-ST, while waiting to build up my Falcon parts.
GoofyFoot
#333 Posted : 16 March 2016 18:04:19
I'm awed by this build. I fully expect to be using this log as a reference once I start getting my kits. I'm trying to save up at least 2/3rds of the total cost before I subscribe, just so I know if I have a bad month or two, I know I'm covered.
Anyway, I just wanted to say, this is amazing! Great work!
If at first you don't succeed,
maybe you should skip the chainsaw juggling...
#334 Posted : 16 March 2016 18:09:45
Welcome to the forum GoofyFoot,
Colsons build is pretty stunning!! I am forum support for USA so let me know if there is anything I can do to help you.
colson
#335 Posted : 16 March 2016 19:40:05
Thanks GoofyFoot. Welcome to the forum. There's a bunch of good builds on here. And feel free to ask questions.
GoofyFoot
#336 Posted : 16 March 2016 22:20:16
colson and darbyvet...
Thanks for the welcomes! There are definitely a lot of talented modelers here, and I look forward to learning from you all!
colson
#337 Posted : 23 March 2016 18:10:40
QUESTION.
So I'm up to issue 60 now. Has anyone who's gotten to this point yet tried running the circuit board with a 9v power supply? I bought a bunch of J2 connectors and am planning on hooking in to the circuit board with another board to run all of my additional lighting. I'd like to test, but I don't wanna fry anything by hooking up a 9v supply. Though Model Space does say it will power from a 9v supply eventually. Or will it really be 6v, which is what the battery compartment is?
adriuus
#338 Posted : 23 March 2016 21:06:00
hi colson
in answer to your question I'm running my lighting of a plug in 9v adaptor and everything is working fine....with all the extras ive added the 6v supply wouldn't stand a chance.....hope this helps.....keep up the great work
colson
#339 Posted : 23 March 2016 22:08:13
adriuus wrote:
hi colson
And that's powering up the supplied circuit board from DeAgostini?
adriuus
#340 Posted : 23 March 2016 22:35:15
yeah...it powers the supplied board....if you look at some of my posts on my build diary you'll see how I've integrated it all to suit how I want to finally display it
http://forum.model-space...osts&t=16124&p=6
Guest (12)
This page was generated in 0.500 seconds.
