4 Pages <1234>
Model Expo 1/16 Fokker DR 1 review Options
#21 Posted : 03 October 2014 15:50:14
That prop looks awesome!!
#22 Posted : 03 October 2014 19:43:10
That prop is a kit in itself and looks very complicated.
I was tempted by the camel kit they had on offer but trying to make up the prop which is a real focal point of a model such as this put me off.
Hope your build goes very well.
#23 Posted : 03 October 2014 23:11:37
BigGrin Very nice work on the propCool
#24 Posted : 03 October 2014 23:15:44
Great skill shown on the prop, it looks fab....Drool Drool
#25 Posted : 07 October 2014 01:52:36
here is the top wing assembly. You have to soak and bend thin strips of wood for the leading edge of the wings.I was worried the wood would crack, but actually it worked well.Otherwise it was just fairly simple
#26 Posted : 07 October 2014 01:54:53
more wing assembly
#27 Posted : 07 October 2014 01:57:08
final wing
#28 Posted : 07 October 2014 01:58:55
2 lower wings
#29 Posted : 07 October 2014 02:00:19
Propellor This was made from 7 parts glued together and sanded to shape
#30 Posted : 07 October 2014 02:01:04
Glued together
#31 Posted : 07 October 2014 02:02:44
The engine was a simple build.The metal parts needed some cleanup, otherwise it was easy to assemble
#32 Posted : 07 October 2014 02:03:56
back of engine with wiring
#33 Posted : 07 October 2014 02:06:00
Ammo cans.These were metal parts with aluminum covers
#34 Posted : 07 October 2014 02:07:52
completed
#35 Posted : 07 October 2014 02:10:05
Fuselage.This was a challenge to build.You had to attach the white metal frames to the jig and then bend brass rod for the 4 longerons
#36 Posted : 07 October 2014 02:12:12
It was really tough to keep everything aligned and the curve in the longerons were compound and really tough to bend.My fuselage ended up twisted even after multiple attempts.
#37 Posted : 07 October 2014 02:13:33
more
#38 Posted : 07 October 2014 02:15:00
more
#39 Posted : 07 October 2014 02:16:38
I used jb weld epoxy to keep the longerons from popping of the frames
#40 Posted : 05 May 2016 12:57:33
Fantastic looking build. keep the pictures coming. look forward to seeing more of this.
regards Ian
Guest (10)
4 Pages <1234>
This page was generated in 0.349 seconds.
