 Rank: Pro  Groups: Registered
Joined: 07/10/2010 Posts: 148 Points: 430 Location: At the back of my sinking boat
Hi Mike the port reply was in answer to Karls remark of port and starboard getting him in a tis and my boat is in Norfolk as there is nowhere in Basildon to take my boat unless of coarse you take the Thames estuary into consideration which is a 5 min drive away at Canvey island Present Build: H.M.S. Victory H.M. Bark EndeavourPhotobox build albumIt cant be that bad, what do you mean it's sinking
Joined: 21/03/2010 Posts: 270 Points: 837 Location: Nr. Dartford,
Nice one Venice. It was easier when port was larboard having an L in it. I'm not actually that old! Laury
Joined: 19/05/2010 Posts: 34 Points: 105 Location: Copthorne, West Sussex
Hi all, I finally managed to find some time to strip my boat of the necessary planks, which was all the planks curving around the bow. the problem had started with the first plank I layed and just got worse and worse as I proceeded up the boat. I have now redone it all and am ready to cut out the second line of ports and continue planking up. I'm so glad that I did this. I'm much happier with my boat now.    Thanks all for your help  E
Joined: 30/01/2011 Posts: 865 Points: 2,410 Location: Cambs
It's coming on well Come on you Jimmies
Guest (9)
