 Rank: Beginner Level 1  Groups: Registered
Joined: 25/11/2016 Posts: 7 Points: 24 Location: norfolk
hello i see , which it is ,it was assembled on straight wood with surport as directed as was inner ribs from keen eye all seam straight and true nothing forced , i took time etc same with planking . i hope this sounds right appricate input id rather sort it now then as you say run into problems later . jim
Sounds good but keep an eye on it as you continue as planking can pull it out of alignment.
 captain parrow nit here i have just noticed and it's back to the drawing board i have pinned planks yet not glued and should have as pins not to in wood ?? arrrrrrrrr it means all start on guns ports over weekend was i n vain thank god for extra wood o well one mistake . were's the rum more to come when caught up captain p !! File Attachment(s): captain parrow attached the following image(s):
hi a guick question how do i check alignment issues excuse confused at moment cap parrow
