 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,713 Points: 17,291 Location: ipswich
It's all looking really good. Nice to see another Shelby build here.
Joined: 19/11/2016 Posts: 133 Points: 404 Location: North Carolina, USA
Thank You Roy for the kind words
Few more mods on engine. rpmracing18 attached the following image(s):
Engine, wiring and hose routing finished and installed in the chassis. rpmracing18 attached the following image(s):
 Very nice
Thanks Capt'n
Few photos of progress. Tapping all the 1.8mm and 2.3mm holes that are in metal. rpmracing18 attached the following image(s):
Keep it coming. It's really interesting to see what you are doing.
Thanks Roy  I'm working diligently and slow, to make sure all assembly sequences are smooth along with the minor modifications from this point.
Got the trunk mat installed, (Thank You Peter for material a.k.a. pbhawkin). Made a template from copy paper. rpmracing18 attached the following image(s):
I won't be covering the spare tire as '67 Shelby's did not come from Shelby American with the tire covered. Again Thanks to Peter (AKA pbhawkin) for sending me the trunk material from down under Australia to me in the US and he sent it to me FREE OF CHARGE
Rear taillights and wiring. Trunk lid attached as well. rpmracing18 attached the following image(s):
Trunk fold down lever and trap door latch. rpmracing18 attached the following image(s):
Joined: 08/09/2015 Posts: 27 Points: 74 Location: Mudgee, NSW, Australia
I am glad it arrived safely and that you found it useful. I think it helps finish off that area! I really like how your model is coming on. I gave mine to my son for his 18 Birthday and he loved it. Although I have yet to make a display case for it.
Thanks Peter,
I do again appreciate the trunk material. I am taking a little time away waiting on a replacement front windshield and back window. The front was way out of alignment and the rear window was scratched evidently during shipment.
Come back often as I'm about to get it completed.
Sincerely, Richie
Few more photos and nearing completion. I had trouble with the windshield molding and ended up having to glue them. The driver's door fitment is terrible. I have had to heat the plastic glass, grind, bend, glue and struggle for fitment. I finally got it to fit fair. And I haven't even tried the fitment on the passenger door yet, hope it will be a better situation. Thanks for looking, Rich rpmracing18 attached the following image(s):
Almost There!! rpmracing18 attached the following image(s):
That has come on very nicely. Mark Regards Markwarren (Mark) Admin
Nearly done. It's been a great build to follow. Looking forward to seeing it in the 'Finished' area soon.
