36 Pages «<34567>»
MWG build diary of Nelson's HMS Victory Options
#81 Posted : 17 July 2011 14:17:09
Thanks for your support FozBigGrin LOL
Lonestar Spirit
#82 Posted : 18 July 2011 12:07:57
Do what your heart tells you, you know you can't go wrong! and if it does, blame everyone on here who put the pressure on you LOL LOL LOL
Ship Builds on the go
#83 Posted : 18 July 2011 12:10:45
Cheers David for those words of encouragement,It will work out fineHuh LOL LOL
#84 Posted : 20 July 2011 13:44:00
Hi everyone, continuing the Port and Starboard entrance enhancements, I have now prepared the Port lintel.
The tools I used have been simple because of the mineute nature of the process namely:-
1) Craft kife
2) Round file
3) Flat file
4) Pencil
5) Small set square
I measured 13mm the width of the entrance, allowed 1.5mm per side for the side panels. there fore the lintel measures 13mm outside and 10mm inside, with curved hips,please take a look:-
#85 Posted : 20 July 2011 13:48:31
I hope I am conveying my process clearly Here is some more info including the measurements:-
#86 Posted : 20 July 2011 13:51:56
now I will cut out the opening to reveal the shape of the lintel:-
#87 Posted : 20 July 2011 13:58:40
First part nearly over, it still has to be fine sanded and shaped, oh I nearly forgot the thickness of the lintel 5mm x 4mm.
I have managed to aquire very thin lead sheet to enhance the canopy when fitted I have included a photo for you:-
So far I am pleased with this baby step,Comments Please are welcomeBigGrin BigGrin LOL
#88 Posted : 31 July 2011 11:21:16
Hi every one I MUST MAKE SURE I ALLOW FOR THE WALES TOP AND BOTTEM OF THE ENTRANCE. ( This is a reminder for yours truley )Blink LOL
#89 Posted : 12 August 2011 12:41:27
Hi everyone this week has been like Christmas, I received my tile pack and today:- Parts 63/64/65 and 66Drool BigGrin
tom.ganc
#90 Posted : 15 August 2011 00:20:32
Hi mate
My tails arrived as well. Just waiting for the instructions to get on it :)
All the best
#91 Posted : 15 August 2011 00:22:39
Same here, will not belong nowBigGrin Cool
#92 Posted : 15 August 2011 08:24:13
Glad to see that you've got your copper plating and your issues MWG...looking forward to your next build posting mate...ThumpUp
#93 Posted : 15 August 2011 09:32:06
Cheers JonnyCool
#94 Posted : 15 August 2011 09:40:36
Wow that's alotta tiles. Keep u busy for a while. ;) Cool
#95 Posted : 15 August 2011 09:45:46
You Bet ChrisBigGrin
riff-raff
#96 Posted : 23 August 2011 20:13:48
If you can get a good image - print it out at the correct size onto photo paper. put about 8 coats of mat varnish over the image. Allow to dry fully between coats.
Once everything is fully dry wet the back of the image and using a small brush remove the paper.
The image should remain in the varnish and can be glued into position.
Good enough as a finish but may fail upon close inspection.
Built:
Tiswas
#97 Posted : 23 August 2011 22:54:54
Good luck with your mod MWG, hope it all works out well for you. Watchingwinterest.
TIS
#98 Posted : 25 August 2011 12:38:40
Cheers Tis and RiffCool
#99 Posted : 04 September 2011 12:08:51
ISSUE 40.
As I have finished as much as I can do on the Endeavour (untill other issues) I have decided to add the Gallery to the OLD GIRL!!
I followed the instructions to the letter, making sure all my measurements were spot on.
Then I soaked the the lower false deck, and fitted it useing PVA Adhesive while the deck was wet:-
#100 Posted : 04 September 2011 12:16:03
Then I added the tabs to the upper false deck, and fitted the complete unit I breathed a sigh of relief when the lugs located in the rear bulkheadFlapper
Guest (11)
36 Pages «<34567>»
This page was generated in 0.294 seconds.
