13 Pages «<56789>»
Gandale’s Enhanced Trumpeter Bismarck Options
#121 Posted : 13 December 2020 14:00:07
Hi coming along very well lots of great detail being added to this,cheers mick.BigGrin
#122 Posted : 13 December 2020 23:14:03
Looks better and better with each update Alan.
Tony
#123 Posted : 14 December 2020 14:56:08
Stunning work Alan. You are definitely a plastic modeller. Your PE skills are amazing.
Chris
#124 Posted : 15 December 2020 17:35:28
More excellent work Alan. Cool Cool Cool
Question:
In post #116 you have the part held in what looks like a vice.
a) is that correct?
b) does it vacuum clamp to the cutting mat its on?
Doh, that`s two questions.LOL
I have an edge of table vice, but if I drop anything I have to beat the carpet monsters to it. If this adheres to a cutting mat I can put it further back on the table to confound the little demons.Blink
I ask because my left thumb is getting worse for grip and it may be a solution to my problems.
Can`t get to see a specialist with the way things are at present, proven by the fact that my wife is still awaiting cataract ops on both eyes that were cancelled three days before the first lockdown early this year.Crying Crying
#125 Posted : 15 December 2020 21:48:11
Thanks again for all the supportive comments guys, appreciated....Cool Cool
Have now decided to jump in at the deep end and start working on the hull of this beast... will post up once I've had a good look and see what needs to be done....
@Derek, I use a multitude of different thing to hold pieces in place but the two vices below are probably the ones I use the most. The first is quite weighty so don't really use the suction pad, I find for most uses the weight of the vice means little movement on the bench. Very versatile, can hold items at various angles which I find very useful... If I do need to clamp it down then I tend to place the vice onto a sheet of toughened glass. The second vice I find works very well for holding some of the smaller parts. Can be clamped to the edge of the desk but I prefer to have it on the centre of my work area... Works for me.... Hope this helps...
#126 Posted : 16 December 2020 09:32:05
I'm guessing this is going to be pretty big...
Looking very impressive.BigGrin
Kev the Modeller
#127 Posted : 16 December 2020 21:43:17
More outstanding PE work on that aft superstructure Alan. I am thoroughly enjoying watching your first forays into using this media and you never cease to amaze me with how skilled you seem to be with it already!
Very well done yet again Alan, keep it coming. Drool ThumpUp
Kev.
Per Ardua Ad Astra
#128 Posted : 17 December 2020 00:57:35
Thanks guys, long way to go and lots to learn on the journey.... loving the challenge though.....Cool Cool
@Roy - she's certainly not small... length 1265mm with a 188mm beam but the detail is tiny.....Cool Cool
#129 Posted : 17 December 2020 23:58:11
Thats a very large size model Alan.
Do you put them all on display when you finish the models?
Tony
#130 Posted : 18 December 2020 02:24:36
Stunning work as always.You will need a LOT of paint.I think I used 6 bottles of Vallejo on my 1/200 Arizona hull.
#131 Posted : 03 January 2021 22:42:49
Happy New Year to everyone, hope you all had a wonderful festive period. For me, I decided to take a complete break from modelling for a couple of weeks. Felt like I needed to chill out, enjoy the festivities and recharge. Now we’re into a new year its now time to get back to doing the serious stuff.
My thanks to all who have looked in a commented, as always it is very much appreciated. Have started work on the hull and here I got a big surprise, on just how much work is needed to be done to the hull section prior to attaching etch, prop shaft housings, rudders etc. Close inspection of the hull revealed many (long) seam lines that needed to be dealt with plus some pretty deep depressions that needed filling and sanding.
Before I got down to the business of filling and sanding I glued the hull cross members in place and the two sections of the bow, then let it all dry. Removed all the seam lines before doing some putty work to sort out the depressions, then removed all the moulded detailing that will be replaced with etch. Also noticed the hole at the front of the bow was situated too low so filled this and sanded ready for re-drilling.
Now ready to start adding the detail so until then, happy modelling.
#132 Posted : 04 January 2021 10:30:35
Hi Alan,
Sounds like fun and a lot of hard work, but it is looking good and well worth the effort,
Best Regards
Trev
#133 Posted : 04 January 2021 11:35:03
Great work Alan. The hull is quite flimsy without them stays an deck in place isn't it. Looking well after the filling and sanding.
What jig is it you are using to hold the hull. Would come in handy on some of my big kits.
Chris
#134 Posted : 04 January 2021 16:32:33
More fantastic work Alan.
You're really going to town on this one.Love
#135 Posted : 04 January 2021 20:18:36
Excellent work Alan.Love Love all that filling and sanding goes to show it is not to dissimilar from wood.BigGrin
Keep up the great work.
#136 Posted : 04 January 2021 20:53:38
Nice work Alan.
I guess some of these kits do need the “old days” attention in sanding and filing but i always think that goves you a sense of achievement when its finished and you look at it snd say to yourself “i had to fix that, i had to fix that” and you can feel satisfaction on a job well done.
Tony
goddo
#137 Posted : 04 January 2021 21:30:40
Great work there Alan. Well done sir!
And after Boris's announcement tonight, we will no doubt be getting more modelling time.
Stay safe everyone and get your vaccination asap.
Chris
#138 Posted : 12 January 2021 21:04:11
Thanks again guys for looking in and all the supportive comments, appreciated.....Cool Cool
Got some more work on the hull done, doesn't look much but took a bit of time. Fitted the bilge keels, prop shaft housings and prop supports. More putty work then onto drilling all of the portholes out using a 1.6mm drill. Noticed here a couple of ports are missing but can't drill them yet. Need to get the ladder positions drilled first to make sure I drill the portholes in the correct position. Finally, went over the whole of the hull with 1200 grit sandpaper to get it all perfectly smooth. Now ready to start fitting some of the etch so until next time.... happy modelling.....
#139 Posted : 12 January 2021 22:39:49
Its another step closer to getting it completed Alan.
That is a lot of work having to sand something so large but its all the important steps to make sure you get a nice finish.
Hope it continues well.
Tony
#140 Posted : 12 January 2021 22:47:23
Thanks Tony, a long way to go but progress is progress.... Certainly a lot more work to building in plastic that I thought but great fun.....Cool Cool
Guest (35)
13 Pages «<56789>»
This page was generated in 0.225 seconds.
