 Rank: Pro  Groups: Registered
Joined: 23/12/2018 Posts: 318 Points: 949 Location: Illinois, USA
Gandale wrote:Looking good, lovely work.... Regards Alan Thanks Alan. Mark Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 9 - Stage 94 Started out by repeating the previous stage on the starboard side. Next I shaped and smoothed out the round gun ports and made a recess on the rail for another round port 35mm forward of the first one. Finished the stage by test fitting the round ports. This was repeated on the other side of the ship. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 9 - stage 95 This stage is more work on the rails and round gun ports. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Very nice work Mark, looking great. Mark Regards Markwarren (Mark) Admin
Mark That is coming aling very nicely and is really taking on some great detail now. Hope it continues well Tony Happy Modelling
This is turning out to be a very nice build indeed, very well done Mark.... Regards Alan
Pack 9 - Stage 96 Continuing the rails aft to the complete the side rails of the quarter deck. Next the the hand rail along the edge of the quarter deck was fitted. 2 two rung ladders were placed leading to the quarter deck. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 9 - Stage 97 This was a short and simple stage. The dolphins were fitted to the bow along the top of the beak and the bottom of the prow. 2x4mm molding was glued from the dolphins to the stern 10mm apart and 10mm from the bottom of the gun ports. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Taking shape very nicely Mark. Mark Regards Markwarren (Mark) Admin
Pack 9 - Stage 98 I've fitted the lower gallery deck to the stern of the ship. The gallery deck supports were added. Next the gallery side panels were glued in place. Finally, the gaps between the gallery sides and the sides of the hull at the stern were filled with 2x5mm planks. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 9 - Stage 99 The side rails are completed all the way to the transom. along with the hand rail between decks. Next, the stern gallery decks are fitted and the sides of the lower gallery is added. The hull is given a final sand and any flaws are fixed. 3 coats of acrylic satin clear coat is applied. Thanks for following Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 9 - Stage 100 In this short stage, the knees were assembled and fitted to the transom. 2 doors were installed on the bow bulkhead. Moving on Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 9 - Stage 101 I started out by painting the brass windows and then installing them on the poop deck and quarter deck bulkheads. A pin rail was fitted aft of the main mast hole. One of the large rails was placed forward of the hole. 2 lockers were fabricated and installed on the quarterdeck. A 5 rung ladder was fitted leading to the poop deck. 2 ladders were installed leading to the quarter deck. That's all folks. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 9 - Stage 102 I painted the back side of the transom. The windows for the stern galleries were painted, built and installed. I installed the heads on the bow deck. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Mark This is taking shape at a pace. It looks really nice. Hope it continues well for you. Tony Happy Modelling
Pack 10 - Stage 103 The rail columns were fitted across the forward forecastle rail. I then prepared the forecastle side gunwales to receive the hand rails. I was unable to finish this stage because for some reason, I came up 20 columns and 2 hand rail fittings short. Hopefully customer service can get me some replacements soon. With the exception of the missing parts, this stage and pack is completed. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 10 - Stage 104 The handrails around the forecastle deck were completed. The Rails on the forward edge of the Poopdeck was also fitted. Simple stage and is now complete. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Excellent build! Loving it!Greetings, Walter
You are doing a great job Mark, looking excellent. Mark Regards Markwarren (Mark) Admin
You're making excellent progress Mark, she's certainly has the makings of turning out to be a stunning build..... Very well done.... Regards Alan
