14 Pages «<678910>»
sandnesspeats Options
sandnesspeats
#141 Posted : 02 February 2013 11:20:15
Dontshootme wrote:
Have you thought of using freshwater fishing hooks,I realise they may be in short supply on the islands but are readily available on ebay etc
Hi rob,
Never thought of that,There is fishing tackle shops on the Island I will have a look today, although I did manage to make some out of electrical wire, same gauge.
Great tip thoughBigGrin BigGrin
Thanks again
rob
#142 Posted : 02 February 2013 11:25:00
this is a perennial problem with eyebolts,if you go to the jotika website there shop does etch eyebolts small enough for the needs of us,they do a sheet of them with a lot of eyebolts.I've used them extensively.
http://www.shipwrightsho...ull-Detail-Fittings.html
daffy09
#143 Posted : 02 February 2013 14:06:27
Hi Karl,
Sorry to hijack Sandnesspeat's thread but just wanted to ask question about the brass etch eye-bolts. Visited your link and they look absolutely fine for our purposes. What size do we need to order to be close to the scale we using? Thanks
David
sandnesspeats
#144 Posted : 02 February 2013 18:59:40
[quote=karl1113]this is a perennial problem with eyebolts,if you go to the jotika website there shop does etch eyebolts small enough for the needs of us,they do a sheet of them with a lot of eyebolts.I've used them extensively.
http://www.shipwrightsho...ll-Detail-Fittings.html[/quote]
hi Karl.
great site thanks
The thing is that would be the ideal thing,BigGrin BigGrin the postage is approx £20,highland and island rates.Cursing Cursing
thanks anyway
rob
sandnesspeats
#145 Posted : 02 February 2013 19:02:00
daffy09 wrote:
Hi Karl,
David
hi david, If you are using them for the cannons they approx 0.9mm for the hole and about 6mm in length.
cheers
rob
court orchard
#146 Posted : 02 February 2013 19:08:38
hi Karl.
great site thanks
thanks anyway
rob
Hi Rob,
Surely that postage is just their express rate to you, ordinary Royal Mail UK 1st class is the same for you and it's about £1.60. It's all I use for my orders and they usually arrive the next day.
sandnesspeats
#147 Posted : 02 February 2013 22:27:16
hi Karl.
great site thanks
thanks anyway
rob
Hi Rob,
Hi karl,
I went to the checkout with the items and it stated £20+ It has a separate pull down menu for Highlands & Islands. I might give them a phone on Monday to check that is really that much. You might be surprised to hear that this is common for the islands when the royal mail is the cheapest and they do come to the islandsBlink Blink at normal postage costs,like £1.60 what you have quoted. Islanders lose out on a awful lot because of it.Cursing Cursing Cursing
PS Just tried it again It does offer royal mail, when they see the address they may not process it because it is going to an Island,as I say might phone them on monday.
cheers
rob
sandnesspeats
#148 Posted : 02 February 2013 22:43:06
hi Karl.
great site thanks
thanks anyway
rob
Hi Rob,
Hi karl,
Yes there are 2 options when I seen it but went in again a `viola` royal mail economy postage came in this time weirdBlink Blink
cheers
rob
#149 Posted : 02 February 2013 23:58:22
did I really say all that??????Blink all I did was put up a web site????
seems I had an awfully long conversation without moving my lips???????
sandnesspeats
#150 Posted : 03 February 2013 16:16:34
hi Karl
I obviously quoted everything that came to me,and got mixed up. sorryBlushing Blushing.
thanks for the website anyway BigGrin BigGrin
cheers
rob
sandnesspeats
#151 Posted : 24 February 2013 10:29:09
HI all,
I have come across a potential problem, I am on issue 55,when doing the deck planking I have noticed that the temporary masts seem to be leaning to one side,will I try and sort this now or what.
Thanks
rob
#152 Posted : 24 February 2013 10:59:05
YES NOW IS THE TIME to sort it ,sorry caps on,really take your time on this one,as it is important that this is set up right,there is a slight backward slant as well,it is called "rake"make sure ship is level on all planes first,then adjust the mast hole on the deck,it will have a wooden ring around the mast,that should cover any adjustments done.
sandnesspeats
#153 Posted : 24 February 2013 12:29:54
thanks Karl,
I will take my time, just was not sure if it was covered at the deck if I have to a lot of adjusting.
Thanks againBigGrin BigGrin
sandnesspeats
#154 Posted : 14 April 2013 23:28:21
Hi all,
I see everybody is still doing great with their builds very impressive.Cool Cool Cool
I just have a question about issue 58, I have made up the cabin partitions before painting but it says about staining the bulkheads etc, I have the paints set and it has walnut paint in that, can I just use that or is that for something else,
thanks
rob
BigGrin BigGrin
#155 Posted : 15 April 2013 08:32:26
Hi all,
thanks
rob
BigGrin BigGrin
Yes if you are painting the ship you can use the walnut paint.
sandnesspeats
#156 Posted : 15 April 2013 14:25:21
Thanks JaseBigGrin BigGrin
sandnesspeats
#157 Posted : 17 April 2013 22:34:56
Hi all
looks as if the dilemma with the aft mast is getting worse,as you can see from the photos the center line is off by about 5 mm , has anybody had this problem or it must be the way I have built it.Blushing Blushing
The only thing I can think of to try and file the bottom of the hole with a round file to bring it reasonably upright, any suggestions would be great.
could I even take off the cross plank and file it to center then make another cross plank as it will not be seen after it is planked,just a thought.
getting fed up now Crying Crying BigGrin BigGrin BigGrin
Thanks as always
rob
#158 Posted : 17 April 2013 23:57:11
hi rob,it would help a lot if you could show the pics, Have you tried attaching to the post? you can edit the pic to resize 800x600 and it will show,give it a try, much easier to see, every time I click on your pics it copies them to my hard drive. and a lot of members won't bother because of this problem. if you need help just ask (about the pics) k.
#159 Posted : 18 April 2013 00:05:32
ok rob,the hole is def. not in the middle is it. so a bit of back tracking required, replace some deck flooring and start again,cut dead centre hole,before gluing,you might have to go lower down,to widen lower deck hole to get the mast straight. leave it any longer and will be too late to fix.
good luck,and take the repair as a phase in the building. k.
sandnesspeats
#160 Posted : 18 April 2013 00:05:36
hi karl,
I tried to delete and re post but it would not show them. this is the first time this has happened, don`t know how this has happened as I have not changed the settings on the camera. if you can help how to change the size of them so it will show that would be great.
thanks
rob
Guest (17)
14 Pages «<678910>»
This page was generated in 0.489 seconds.
