14 Pages «<7891011>»
Aviation Quiz Options
#161 Posted : 24 March 2013 14:30:19
Yep!!Flapper LOL BigGrin Over to you Kev!!BigGrin
SennaMentalMe
#162 Posted : 26 March 2013 18:52:42
Thanks Daran. BigGrin
Name the aircraft:
Crew: 5
Length: 114 ft 11 in (35.05 m)
Wingspan: 110 ft 0 in (33.53 m)
Height: 28 ft 1½ in[11] (8.57 m)
Wing area: 2,406 sq ft (223.5 m²)
Empty weight: 89,030 lb[76] (40,468 kg)
Max. takeoff weight: 205,000 lb (93,182 kg)
Powerplant: 4 × Armstrong Siddeley Sapphire A.S.Sa.7 turbojets, 11,050 lbf (49.27 kN) each
#163 Posted : 26 March 2013 22:28:55
Handley Page VictorBigGrin
SennaMentalMe
#164 Posted : 26 March 2013 23:07:19
That's the one - you're cleared for take off mate!! LOL LOL ThumpUp
SennaMentalMe
#165 Posted : 08 May 2013 23:34:53
Time for another aviation question Daran? Glare Huh BigGrin
#166 Posted : 08 May 2013 23:52:29
Ooooops!!! LOL BigGrin
Ok, what was the biggest gun to ever be fitted on an aircraft???
Dontshootme
#167 Posted : 09 May 2013 08:43:09
I believe that is the 105-mm M102 Howitzer cannon fitted to the AC-130 gunship,although it was tried as an experiment by the italians during WW2 usin g the Piagio P.108A heavy bomber as he test bed,it never saw action....thankfullyBlink
#168 Posted : 09 May 2013 19:18:20
Correct that man!!BigGrin BigGrin BigGrin
Dontshootme
#169 Posted : 11 May 2013 09:46:00
What is this wierd looking plane?
SennaMentalMe
#170 Posted : 20 May 2013 17:35:34
Hello Rob,
Is it a very early 'experimental' prototype of the Boeing V-22 'Osprey' Tilt-Rotor aircraft?
Or possibly an 'experimental' prototype of the Canadair CL-84 'Dynavert' Tilt-Rotor aircraft?
Dontshootme
#171 Posted : 20 May 2013 20:55:55
Neither i'm afraid,however it was an experimental prototype tilt rotor.Can't say anymore i'm afraid as that would give the game away..I will say that later in its development it was taken over by Boeing.
SennaMentalMe
#172 Posted : 20 May 2013 23:22:38
It was the Vertol VZ-2 - developed by NASA from 1957 until 1965 in which time it made 450 flights!! Only one aircraft was ever made which is now preserved in the U.S.
Vertol later became Boeing Vertol. BigGrin BigGrin
Dontshootme
#173 Posted : 21 May 2013 08:37:28
See,I told you it would give the game away if I gave clues.Crying
Over to you Kev
SennaMentalMe
#174 Posted : 21 May 2013 11:17:10
Hello Rob, to be honest my friend you didn't give the game away with any clues - I did an AOL search for images of VSTOL aircraft and came across the same picture. Great question by the way, I found that to be some very interesting research - thanks!!
My question:
NOT including the Red Arrows (past or present) name four RAF Display Teams whose names have included a colour and I also want to know the type and mark of the aircraft that each team used for display?
SennaMentalMe
#175 Posted : 23 May 2013 23:37:09
Anybody want to have a try at an answer for this one then?? Huh Smile
#176 Posted : 23 May 2013 23:51:01
1 Black Knights-de Havilland Vampire & Hawker Hunter
2 Blue Diamonds-Hawker Hunter F6
3 The Red Pelicans-Provost T Mk4
4 Yellowjacks- Folland Gnat
And for a bonus point
5 Black Arrows-Meteor F8 & Hawker Hunter F6 Flapper Flapper LOL BigGrin BigGrin
SennaMentalMe
#177 Posted : 24 May 2013 00:09:02
C'est la réponse que je cherchais Daran, mais pas de bonus pont j'ai peur que cela n'a pas été offert! C'est à vous mon ami!! BigGrin Flapper Flapper Glare LOL
#178 Posted : 24 May 2013 00:16:58
Merci mon ami!!Flapper Flapper LOL LOL LOL
Right back to the native tongue!!LOL LOL LOL
What aircraft had a total cylinder capacity of 50 Litres, and how was it done and what power output was achieved?BigGrin BigGrin
#179 Posted : 24 May 2013 10:36:04
sorry nem a bit confused on this one(old age) engines are usually given in cubic centimeters ???? litre usually refers to the fuel capacity.?? can you clarify please.Razz RollEyes Sneaky Unsure
SennaMentalMe
#180 Posted : 29 May 2013 16:34:47
Could you clarify your question please Daran?
Guest (8)
