 Rank: Pro  Groups: Registered
Joined: 30/08/2012 Posts: 336 Points: 857 Location: London
I have been spraying my decorations up with Tamiya TS-21 as suggested by Mr T.
I need to touch up a few fixed parts by hand. I can't use the spray, so what colour can I use that will match the TS-21, or can you somehow get the paint from the can to brush with?
Hi Rob I have needed to do this many times, you can just hold a small container like a lid near the spray can nozzle and squirt a little against the side, it will stay liquid for a good while and can be brushed on. Your brush cleanup will then have to be done with turps though. Steve
I agree with Steve, touching up with anything else is likely to give you match issues. “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Cheers fellas, I'll spray some out. I only need a tiny bit anyway. Just where I had to pull one of the decorations off and the paint came off slightly. Nothing major at all.
