Joined: 05/04/2016 Posts: 705 Points: 2,118 Location: Ferrara
DaDokta wrote:Yeah, it`s a big one!
Yesterday i attached some decals to the Chassis: Unfortunately one of the "powered by Honda" decals wasn`t of the best quality - have to live with that (and display the car from the left side!).
One question: Should i put a layer of clear varnish over the decals? Normally i would do that, but as the chassis is varnished already, i`m not so sure.
Thanks! Quote the same questions. I also purchased the Autograph Decals. I would know if once fitted, i must spray clear coat on the body. I use Tamiya TS 13 clear gloss Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Rank: Master Groups: Registered
Thanks Mr.T - so i`ll leave it as is! Greetings, Walter
Hello Walter,
I agree with Tomick, if you are happy with the finish as it is, then it's good enough? The other option if you aren't happy, might be to use a model specific wax polish but tested first on an inconspicuous area, though to be honest I wouldn't even bother with that as the bodywork looks fine to me.
Kev
DaDokta attached the following image(s): Greetings, Walter
You have achieved a fabulous end result to your build Walter, you should rightly feel very proud - very well done indeed!!
Kev
Lovely job Walter.
You've done a splendid job with decals, the overall finish Is stunning! I'm sure this will get lots of attention once it's on display in its case
Thanks guys! Greetings, Walter
Hi guys!
As all my photos were cancelled by photobucket. I re-attached some of them - but only the more important ones.
Therefore i would like to provide a link to all the pics of this build:DaDokta`s MP4/4 GalleryGreetings, Walter
