Rank: Master Groups: Registered
Joined: 26/04/2014 Posts: 1,172 Points: 3,422 Location: Essex
Stage 65 done. Harnesses Fuel filler valve and gear linkage bearing housing Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
Stage 66 started. Yes them stickers are small and very fiddly! Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 66. Electrical system. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
That's stage 67 and pack 19 done. Waiting for pack 20 now, the final one! I can't believe this has nearly finished now! Instrument panel Brake balance adjuster. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Looking good those small stickers are a challenge at times Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Luckily my eyes are half decent. I didn't even use the magnifying lamp! Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Well it's here and Christmas has come early for me as I received pack 20, the final pack! Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 68 started on. The instrument panel wiring done. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Tonight's work. Throttle cable Instrument panel and wiring, seat fitted. Running cabling. I decided not to use the kit tape as it's no good and keeps coming off. So I used black insulation tape cut to size instead and, touch wood, it seems to be staying on! Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Nicely done and I did the same with the tape aswell Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks Andy Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 68 done. Cdi unit Telemetry unit Electrical system part b which I am assuming is the ecu, I could be wrong Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 69 started on. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Looking good
Nice work Steve, all very neat and tidy and looking good. You must be getting excited, being quite close to completion now? You'll soon be putting your finished model on display for all to admire!!
Kev
Thanks for the comments. More body work done. Cockpit cover and oil cooler duct glued in place. Side pod outlet ducts Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 69 finished. Outlet ducts fitted and lower black trim stickers fitted. Mirrors Kill switch fitted to the roll hoop and rear light sticker Just 1 stage to go! Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
And the fiddliest! All looking good though but I bet you utter a few swear words with the fitting of the rear wing.
Got that to look forward to then! The body coming along Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Here we go then, the final stage of what has been a fantastic build. Turbo stickers Chassis number plate. I chose (like probably most other people) the number 2 chassis which was sennas Japanese gp race car. The other choice was the number 5 chassis which was his car in practice for the same gp. Roll hoop lowers fitted Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
