Rank: Elite Groups: registriert, Registered Joined: 20/03/2011 Posts: 2,356 Points: 7,122 Location: UK
The Steering rod ends are part of the kit and it was just the screws replaced by bolts from RBMotion. @ Saleem. There is always room for improvement for any kit, be that Tamiya or any other make if you decide to enhance it but as this kit stands it is head and shoulders above anything else of this scale. Spencer
Rank: Pro Groups: Registered
Joined: 05/05/2014 Posts: 230 Points: 657 Location: Northeast USA
Dear Salem: What you say may be true , but one would need a high level of modeling skills to build the kit you are speaking of-- the DeAgostini McLaren can be built with minimal modeling skills and the builder will be rewarded with a fine quality beautifully finished museum replica that can holds it's own even compared to a very expensive factory built 8th scale model of the same car.
