Dan A model to build in your own time and not to be rushed. It looks so delicate but very impressed how there are no excess glue marks at all - that takes some doing. hope it continues to go together well for you. Happy Modelling
Rank: Elite Groups: registriert, Registered Joined: 20/03/2011 Posts: 2,356 Points: 7,122 Location: UK
Beautiful work Dan Spencer
Really really nice job, boy does she look delicate though!! Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Looks a very delicate and detailed build. Well done for persevering with it despite the unclear instructions
Nice progress Dan, looks a beautiful kit Steve
Looking great Dan, credit to you.... Regards Alan
Rank: Pro Groups: Registered
Joined: 27/06/2011 Posts: 434 Points: 1,309 Location: milton keynes
Thank you so much for all the kind comments, very much appreciated. as careful as i can be, ive still managed to break a few ribs, luckily all easily repaired. ive taken a little step back in order to be able to move forward i had assembled and glued in place all of the strut fittings/attachments with an after thought of "blackening" them off. Having never used "blacken-it" i thought i could just brush on the liquid and the magic would happen!! clearly not . So i thought i would just paint them flat black, not a good effort on my part . so i then thought i would remove them and then leave them in the "blacken-it" solution. great but they all fell apart, clearly glue was just not good enough, out came the soldering iron all re-assembled and dropped into the "blacken-it" solution. fantastic stuff when used correctly . Therefore since my last post ive pretty much had to re do all the work i had done, but the strut fittings all look the part now and should be very strong. so heres a few assembly photos and the finished strut fittings dandare attached the following image(s): Built - MP4/23, Zero, Deagostini Falcon, Model Airways 1903 Wright Flyer, Senna Mp4/4. Working - Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4 on the bench, Model Airways Sopwith Camel.
Fantastic build.
Dan Really enjoying seeing this one coming together you are doing a great job. Hope you have a safe display area set aside because this one looks so delicate. Happy Modelling
Beautiful build Dan and it looks as if it requires a great deal of patience and skill, both of which you are showing in abundance..... Excellent work and a pleasure to see come together.... Regards Alan
Thanks Guys ive managed a few more bits over the last couple of days started on assembling the elevator, the elevator control frame, landing skid and the wing struts. also managed to get the wing warping control wires in dandare attached the following image(s): Built - MP4/23, Zero, Deagostini Falcon, Model Airways 1903 Wright Flyer, Senna Mp4/4. Working - Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4 on the bench, Model Airways Sopwith Camel.
Hats iff to you for perservirance. She will definatly be worth all the effort jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Joined: 04/11/2014 Posts: 1 Points: 3 Location: California
dandare wrote:a few more bits completed must admit this will be slow progress as i feel the instructions are not very clear! does anyone else that's completed a model airways kit feel this way??
regards Dan Dan - I just joined the Model Space forum because of your photos of the Wright Flyer. I am also working on this model and have found your photos helpful. I agree that the instructions are somewhat confusing and now that I have studied (I must admit, for days) the warping pulley and the rigging I am at a loss. Would it be ok if I send you a photo of the warping cable template with my notes as to what I think I should do and then you can tell me where I may be going wrong? While I think I am a decent builder I am not not in your league. Your work is beautiful.
Hi Moneyg welcome to the forum i certainly spent a good few days surfing looking for photos's to help work it all out, and was still confused. by all means PM me the photo, and im sure we will have you warping away regards Dan Built - MP4/23, Zero, Deagostini Falcon, Model Airways 1903 Wright Flyer, Senna Mp4/4. Working - Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4 on the bench, Model Airways Sopwith Camel.
jase wrote:Hats iff to you for perservirance. She will definatly be worth all the effort
jase thanks Jase all true Regards Dan Built - MP4/23, Zero, Deagostini Falcon, Model Airways 1903 Wright Flyer, Senna Mp4/4. Working - Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4 on the bench, Model Airways Sopwith Camel.
well im really pleased with progress so far, the fuel tank and radiator are installed along with the fuel pipe and rad pipes, also managed to get the wing rigging completed and therefore the wing is now off the Jig. landing skid attached and wired up, and the elevator control frame assembled, elevator in place just need the rigging added. regards Dan dandare attached the following image(s): Built - MP4/23, Zero, Deagostini Falcon, Model Airways 1903 Wright Flyer, Senna Mp4/4. Working - Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4 on the bench, Model Airways Sopwith Camel.
Been slowly adding a few cables here and there, so not much of a difference to be noticed! Only managed half of the cables on the Elevator so far. ive also managed to assemble the Rudder which is only temporarily fitted to the main wing at the moment just to give her the little bit extra on the visuals regards Dan dandare attached the following image(s): Built - MP4/23, Zero, Deagostini Falcon, Model Airways 1903 Wright Flyer, Senna Mp4/4. Working - Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4 on the bench, Model Airways Sopwith Camel.
Rank: Administration Groups: Registered, Forum Support Team, Administrators, Global Forum Support Team, Moderator, Official Builds Joined: 09/11/2012 Posts: 7,980 Points: 23,119 Location: East midlands
absolutely stunning build
Beautiful display of craftsmanship..... .. Looking great..... Regards Alan
