Joined: 30/09/2014 Posts: 16 Points: 54 Location: Harrisburg, Pa. USA
Time to get to work. I started cutting and dry fitting all the Bulkheads As of today this is where i am. I'm starting on the deck now. as i progress i will update. Thank you for taking the time and checking out my build. _______________________________________________________________ If they can make it BIG, I can make it small....... Wayne RUFFNITEModel Space HMS Surprise, http://forum.model-space...spx?g=posts&t=13545
Great work with jig, looks like you are to a flying start.
Enjoy your build, I will be following
Ruffnite A very warm welcome to the forum. Well you gave certainly picked a wonderful kit to build. From some of the other build diaries I have seen this is a really detailed kit and can be turned into one very impressive model. Not a criticism but was wondering about your bolts through the hull pieces. Not seen this done by anyone using this type of jig. No major issues as far as I can see other than your going to have to remove them well before the planking prevents you doing so. Looks like your off to a great start and looking forward to your further updates. Happy Modelling
Welcome to Modelspace great start to your build and Im looking forward to seeing it progress, good luck Steve
Welcome to the forum and a very nice start Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Warm welcome, will be following your progress with interest.... .. Good luck with your build. Regards Alan
Rank: Pro Groups: Registered
Joined: 02/04/2013 Posts: 174 Points: 534 Location: Bethlehem PA, USA
Welcome to the forum! I have the same story as you. Built a ton of plastic but this is my first Wood model as well.
The only difference is that it will take you literally 15-20 times longer than any plastic kit you ever built. Ha Ha!
Also, this is no paint by numbers as you'll soon find out. Tons of research and patience is the key here.
My advice would be to treat every step you take almost as it's own model, and while keeping an eye on the prize and always planning ahead, once you start a particular step, just concentrate on that step and don't jump around too much. As an example, right now I'm working on the yards. I estimate just building all of them and not even installing them will take me a good 80 hours if I'm lucky. So I got my plan of attack and that's all I will think about until that step is completed. At least that approach works for me.
It's a friendly group here however so please take advantage of us and ask tons of questions as you go. Between all of our opinions I'm sure you'll get some good ideas.
BEST OF LUCK!
PS - In my post you can find links to a lot of early build pics. They might be helpful to you, especially around the Great Cabin where the instructions are truly lacking.
Rank: Administration Groups: Registered, Forum Support Team, Administrators, Global Forum Support Team, Moderator, Official Builds Joined: 09/11/2012 Posts: 7,951 Points: 23,039 Location: East midlands
Hi Ruffnite, You`ve picked a BIGGUN for your first wood build. I`m presently collecting this one and holding for later, but I wish you all the best in your venture. Any questions, just ask away. Someone will have the answer on here or help you find it. You`ve made a good start , keep the pics coming Happy Building, Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Looking good, keep posting those pics.... Regards Alan
very good start, it's your model,so build it your way,we are just here to help. if needed. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
build your model the way your happy with my friend, great start Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Ruff mite No offence intended questioning your bolting of the hull to the brackets - it was just something I had not seen before. Kind regards Happy Modelling
Tony, oh my i took no offence, in fact it did turn out to a bigger pain in the butt then it was worth. gone with the bolts lol though it did hold all things square for as long as i needed it too, it was in the way. lesson #000001 learned reagards wayne ps. please don't hesitate to ask and comment. it keeps me thinking and learning. thank you _______________________________________________________________ If they can make it BIG, I can make it small....... Wayne RUFFNITEModel Space HMS Surprise, http://forum.model-space...spx?g=posts&t=13545
Oh, Forgot to mention I've procured the entire audio version of Patrick O'Brians books. Though I've read them all it's so nice listening to them while i build...YAAAA!!!!! _______________________________________________________________ If they can make it BIG, I can make it small....... Wayne RUFFNITEModel Space HMS Surprise, http://forum.model-space...spx?g=posts&t=13545
Hi all, it’s been a little while since my last post so I thought id catch ya’ll up with my project. What I’ve been working on more than anything is building some specialty tools. First is a mini lathe. I was going to build one from scratch incorporating my Dremel 200 tool as my power supply. Then it dawned on me, about 6 years ago or so I bought a lathe from grizzly tools that used a hand drill for the motor. Now I needed something a lot smaller and one that would allow me control the speed and torque of the motor a lot more betterer then a hand drill lol. So I dug it out and finialy after 6 years I opened the box to see what it looked like. Low and behold the dremel fit into the mounting perfectly square and secure. After playing around with it for a while I realized I was handed a gift from the Gods perfectly fit for the task at hand. Following are some photos of the set up and the link to the page, and it Looks like it is still offered at a very good price for everything that comes with the kit. http://www.grizzly.com/p...Lathe-Disc-Sander/H2669
the lathe with the dremel tool instead of a hand drill _______________________________________________________________ If they can make it BIG, I can make it small....... Wayne RUFFNITEModel Space HMS Surprise, http://forum.model-space...spx?g=posts&t=13545
As i played around with the set up a while i could see this will work out nicely. _______________________________________________________________ If they can make it BIG, I can make it small....... Wayne RUFFNITEModel Space HMS Surprise, http://forum.model-space...spx?g=posts&t=13545
Next i busted out the good ole dremel router part number 231. also works nicely as a sanding tool _______________________________________________________________ If they can make it BIG, I can make it small....... Wayne RUFFNITEModel Space HMS Surprise, http://forum.model-space...spx?g=posts&t=13545
