Joined: 15/03/2014 Posts: 14 Points: 35 Location: australia
G'Day guys, been a while since my last cry for help. Just finished marking up all gun ports (issue 35). Cut out the bottom row and behind the last one (aft of rib frame 26) I was shocked to find frame 49 that was fitted in step 4 issue 16, and there is no gun platform ????????????? what have I Done? Steve.
Hi Steve, if I understand you correctly then I don't think you have done anything wrong. The very last port on the bottom row is actually a closed port, no gun present as shown on my diary, link below.. http://forum.model-space...ts&t=5013&p=149
Hope this helps. Regards Alan
Thanks Alan, that a relief - I had applied the old measure twice -cut once rule, particularly to the gun ports and could not understand what went wrong. I had intended to make it a closed door even if I did stuff it up. thanks again regards Steve
