Rank: Pro Groups: Registered
Joined: 14/04/2015 Posts: 238 Points: 716 Location: Newcastle
Hello to all the SOTS builders. I'm have currently finished the first 9 issues, I will be buying a camera to use instead of my mobile so hopefully the image quality will improve. Keel JigI built my keel jig from a B&Q shelf and a couple of MDF boards I had left over from a matchitecture build. The jig has been built to allow the bow and stern guide pieces to be easily replaced for future projects. Picture 1 Picture 2 BulkheadsAll the bulkheads have been fitted (dry fit for stern bulkhead). Picture 3 There is an approximate 3mm drop in the deck level from the last to 2nd last bulkheads, can anyone confirm this is correct so I can make any necessary changes before I add the first false deck? Picture 4 CannonsIt took a bit of patience to make the blocks, I use a drop of superglue on the final twists to reduce the risk of them parting once the excess wire is cut. I need to remember to file the flash down on the cannons in future. Picture 5 Picture 6 AnchorI will probably rebuild this when I get the other three. Picture 7 michael.rolph attached the following image(s):
Im no expert with these blank on frame ship builds but it looks like you got off to a good start, the cannons look pretty cool too
Rank: Administration Groups: Registered, Forum Support Team, Administrators, Global Forum Support Team, Moderator, Official Builds Joined: 09/11/2012 Posts: 7,940 Points: 23,006 Location: East midlands
Hi, Looks like a very good steady start to your build. On a more funny side, don`t listen to davetwin. If you had a "BLANK" on frame ship it would sink without trace. "Sorry Dave couldn`t resist that one" "PLANK" Keep up the good work and look forward to you progressing with your build. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Michael, great to see another SOTS build underway and looks like you are off to a great start too.... As for your question on the deck levels, you are correct, the deck drops slightly from the bow to the centre then rises again towards the stern.... .. Keep those pics coming.... Regards Alan
Nice start keep the pics coming Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Michael..Great start there...Look forward to more posts on your build... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Hi Micheal. Great start look forward to seeing more of your build Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks everyone for the kind words and encouragement. I have completed most of issues 10-13 Prow: Picture 1 Deck: Picture 2 Ships boat: Picture 3 Picture 4 I made some mistakes with the planking of the boat but hopefully once it has been painted it should be OK. I am leaving the boats anchor until I paint the rest of the fittings. michael.rolph attached the following image(s):
Joined: 31/03/2013 Posts: 127 Points: 395 Location: london
That's some nice clean and tidy work Michael keep up the good work,robby
I have completed issues 15-17, the only problem I had was that the bucket handle was too small and I snapped it trying to open it out. I attempted to make a replacement using a spare pin from the first deck. This didn't work as I couldn't get the arch correct. I Instead created a handle out of milliput. michael.rolph attached the following image(s):
Some lovely work there Michael Looks like this is going to be a great build. Steve
Coming along very nicely Michael, well done.... .. Another idea you may like to consider for the bucket handles is to use some rigging thread. I didn't like the handles provided so decided to change them, rigging thread is held on with a little superglue... .. Pics on this page of my diary will give you an idea of how it would look.... Hope it helps... http://forum.model-space...ts&t=5013&p=160
Regards Alan
Nice to see new SOTS build stunning work Michael Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Well it's been quite a while since I've done anywork on my Sovereign. I've finally got the time and space in my new house to get on with the hull shaping and filling. It took quite a lot of effort to do the rough shaping of the balsa filler. I ended up buying a Black and Decker mouse sander and finishing it up by hand. With my Build of the year nearing completion I will hopefully have more time to devote to this build. michael.rolph attached the following image(s):
Coming along well and great to have an update from you
Very nice work on the hull shaping, you'll find now this will assist greatly when it comes to planking.... nicely done..... Regards Alan
looking good Michael very nicely done on the fillers she should plank up nicely Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Nice, very nice. Great shape to the hull, so well worth the time and effort spent.WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Been a while since I've made any progress on my build. Now I have finished my victory cross section I will have some time to progress on this build (at least until the BOTY 2018 starts). I've prepped my work space and sorted through my backlog of delivered issues. It looks like the postman has lost one of the deliveries as I am missing issues 97,89 and 100. So its continuing planking tomorrow.
Look forward to seeing you pick up this build again Michael, am sure the wait will be worth it.... Regards Alan
