Rank: Pro Groups: Registered
Joined: 22/04/2015 Posts: 134 Points: 378 Location: San Diego, CA
I'm curious why you put primer on the cockpit door that the decal will get attached to? Are you planning to hand paint instead of using decals? I'm very curious what you will be doing with that part and lighting. The paint booth looks great!! You whipped that up in no time, very impressive! --Impatience Current Build: Millennium FalconWish List: Lamborghini Countach LP 500S, Red Bull Racing RB7
Joined: 28/05/2015 Posts: 26 Points: 78 Location: Oklahoma
Great work on the spray booth... I need to do something similar as I'm new to having to paint items in this fashion. I may try to steal everything you did there And congrats on your goal of quitting smoking, I smoked for a number of years and it's very nice not to have to worry or think about them anymore. Not to mention they now cost 4x what the did when I started as a teenager.
Joined: 17/05/2015 Posts: 61 Points: 189 Location: PIckerington, Ohio USA
Impatience wrote:I'm curious why you put primer on the cockpit door that the decal will get attached to? Are you planning to hand paint instead of using decals? I'm very curious what you will be doing with that part and lighting.
--Impatience Thanks Impatience, I am planing on painting the bulkhead in German grey, I am also thinking about fill in the holes with clear window maker glue once that is done i will flip the bulkhead over and using Tamiya clear blues greens and reds to accent the led lights and decals, seen it done on other models... Adam
Adam
galactiboy wrote:Great work on the spray booth... I need to do something similar as I'm new to having to paint items in this fashion. I may try to steal everything you did there And congrats on your goal of quitting smoking, I smoked for a number of years and it's very nice not to have to worry or think about them anymore. Not to mention they now cost 4x what the did when I started as a teenager. Thanks, it works for what i am doing and lets me build something out of toothpicks and duck tape!!! I am slowly getting better about the smoking, cravings are less each day. I just have to give myself time...
Adam
Lighting and paint ideas DwCr13 attached the following image(s):
Adam
DwCr13 wrote:Impatience wrote:I'm curious why you put primer on the cockpit door that the decal will get attached to? Are you planning to hand paint instead of using decals? I'm very curious what you will be doing with that part and lighting.
--Impatience Thanks Impatience, I am planing on painting the bulkhead in German grey, I am also thinking about fill in the holes with clear window maker glue once that is done i will flip the bulkhead over and using Tamiya clear blues greens and reds to accent the led lights and decals, seen it done on other models... Adam Sounds great! I'm looking forward to seeing how it turns out. I've already applied decals, so I won't be making any modifications to that area, but I'm getting REALLY tempted to start making other modifications. Must...stick...to...OOB...build...UGH! ;) Current Build: Millennium FalconWish List: Lamborghini Countach LP 500S, Red Bull Racing RB7
Impatience wrote:DwCr13 wrote:Impatience wrote:I'm curious why you put primer on the cockpit door that the decal will get attached to? Are you planning to hand paint instead of using decals? I'm very curious what you will be doing with that part and lighting.
--Impatience Thanks Impatience, I am planing on painting the bulkhead in German grey, I am also thinking about fill in the holes with clear window maker glue once that is done i will flip the bulkhead over and using Tamiya clear blues greens and reds to accent the led lights and decals, seen it done on other models... Adam Sounds great! I'm looking forward to seeing how it turns out. I've already applied decals, so I won't be making any modifications to that area, but I'm getting REALLY tempted to start making other modifications. Must...stick...to...OOB...build...UGH! ;) lol, i understand, I keep wanting to start "jumping" ahead of myself and do things but i promised myself i would take my time with this project!!! Stick to your guns and build your Falcon the way you envision it!!!
Adam
well started working on painting and have been working on dry brushing... DwCr13 attached the following image(s):
Adam
Joined: 27/06/2011 Posts: 434 Points: 1,309 Location: milton keynes
Sweet Job keep those updates coming regards Dan Built - MP4/23, Zero, Deagostini Falcon, Model Airways 1903 Wright Flyer, Senna Mp4/4. Working - Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4 on the bench, Model Airways Sopwith Camel.
Very impressive...and yes keep those updates coming I will be following closely.
thanks guys, here are some more pics, been working on the nav seats and bulkhead, also got the shadowing and hull base coats done, the control yokes and paints and love the way they came out, did a base coat of gun metal and then highlighted the hand grips in rubber black and center mounts in silver and black rubber, gave it great contrast and breaks up the form... as for pics sorry if they are fuzzy and if i repeat photos Adam DwCr13 attached the following image(s):
Adam
few more days and should be getting shipment number 2!!!!!
Adam
still waiting on the next shipment, moved my workstation to a more permanent and lees dining room table location!!! also got the nozzle ports drilled for the quad cannons pics to follow soon.
Adam
Started working on the main hold and Cockpit side panels, trying a trick from Tony Fairclough, face book friend, play book with adding a silver base then working my way up in layers from there... may this hold NEVER look this new and clean again!!! DwCr13 attached the following image(s):
Adam
Shiny, be curious how this looks once it's done. I could see the silver being a great base. And if you add any scratches later on it would have a very authentic look.
And I may have missed it, what did you do to get the color variations on the back panel of the cockpit? That looks really good so far.
Rank: Semi-Pro Level 2 Groups: Registered
Joined: 09/06/2015 Posts: 76 Points: 228 Location: Lancaster, CA
I'm very curious also. I've not seen this yet either but the Man has a plan. What do you know that we don't? Tamiya 1/32 P-51D, Revell 1/32 Bf 109G-6 x2 1/32 P-51B, 1/32 Trumpeter Bf109K-4, 1/32 Hasegawa Bf 109E, Testors 1/32 F-117, RMF 1/35 Tiger 1
galactiboy wrote:Shiny, be curious how this looks once it's done. I could see the silver being a great base. And if you add any scratches later on it would have a very authentic look.
And I may have missed it, what did you do to get the color variations on the back panel of the cockpit? That looks really good so far. That's the plan, For the cockpit Bulkhead I filled in the holes with clear window maker, once that had dried and set I painted the spaces with Tamiya clear blue and red paints... that pic was taken with a led flash light in a coffee cup to simulate the passage way that comes with the kit, once i get the model led and battery pack going i will re-eval the colors and add more if need be... thanks for the response!!!
Adam
dwayneg wrote:I'm very curious also. I've not seen this yet either but the Man has a plan. What do you know that we don't? One of the guys I am following on facebook and Youtube is building the Bandia sets and when he did the R2D2 he used a silver base and then fine misted the blues for the dome and body. it gives this great effect of metal flake, even though its nots a Falcon build its a great watch for weathering, I watch both Him and Foxx Wolf at model Making Guru https://www.youtube.com/watch?v=TNlm4xvwuao
Adam
DwCr13 wrote:[quote=dwayneg]I'm very curious also. I've not seen this yet either but the Man has a plan. What do you know that we don't? One of the guys I am following on facebook and Youtube is building the Bandia sets and when he did the R2D2 he used a silver base and then fine misted the blues for the dome and body. it gives this great effect of metal flake, even though its nots a Falcon build its a great watch for weathering, I watch both Him and Foxx Wolf at model Making Guru https://www.youtube.com/watch?v=TNlm4xvwuao[/quote] I used clear Tamiya colors also on the back side for the cabin Bulkhead sticker. I like the way it turned out. Its not as bright when I put a light behind it. I watched the link he has very good ideas and he's funny. Thank you for that. I have following Foxx on his builds. Tamiya 1/32 P-51D, Revell 1/32 Bf 109G-6 x2 1/32 P-51B, 1/32 Trumpeter Bf109K-4, 1/32 Hasegawa Bf 109E, Testors 1/32 F-117, RMF 1/35 Tiger 1
dwayneg wrote:I used clear Tamiya colors also on the back side for the cabin Bulkhead sticker. I like the way it turned out. Its not as bright when I put a light behind it. I watched the link he has very good ideas and he's funny. Thank you for that. I have following Foxx on his builds. They are both great guys, I don't know if Foxx is on this forum or the UK, but the both are on the Facebook forum and always willing to answer question or give advice, just be willing to hear every other word being Starship Filth lmao!!!
Adam
