Great stuff and congrats on your first print. I have had the same problem as yourself with the Pumkin print I did, print starting in different places a few times and slid sideways like yours in the print process. I actually think its the downloaded code doing this and not the program were using as when you load it into the program it may get corrupted and you get the bad result but load it again and its ok. Bit of a lottery at times but all part of the fun. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Congrat's on your first print, Mr Owl looks great
Joined: 17/11/2015 Posts: 60 Points: 183 Location: USA
Thanks everyone!
Carl, I fiddled around with the repetier host centering as you mentioned, and I believe that will help a lot. I seem to be getting leakage around the nozzle assembly. I tried tightening the nozzle again, but it still has melted PLA leaking out. Anyone have this issue? Thanks
Rank: Super-Elite Groups: Registered, Moderator, Tech Support, Technical Support, Forum Support Team, Forum Support USA, Global Forum Support, Global Forum Support Team Joined: 17/12/2013 Posts: 3,983 Points: 11,974 Location: NY, USA
Not had that issue.I think if I remember you had to tighten it when it was hot but I am not sure.Check the instructions.That may be your problem. Carl ps Here is a link to the official build diary where Mr T talks about tightening the nozzle when it is hot http://forum.us.model-sp...spx?g=posts&t=17252
AgentRev, did you fix your nozzle leaking. If not you can use heat proof threadlock to seal the thread an prevent leakage
Oh thanks, I will probably try that, as I already tried tightening it while hot.
Isn't the printer supposed to move to the center of the bed to begin printing? Mine is not doing that. Does anyone know how I can adjust that? Thanks Edit: actually it looks as though it may be okay now. It just isn't in the exact center, so I'm not sure what the issue could be. Fidget spinners seem to be the sudden rage here in the USA, so wish me luck. lol
