Tail LED Lights Constant Blue = the drone is linked with the radio control handset. Flashing Blue = headless mode enabled. Constant Red = the compass is calibrated. Flashing Red = the compass should be calibrated. Constant Green = three or four satellite signals coupled. Flashing Green = coupled onto 5 or more satellite signals (optimum conditions for flight).
Beeps Single beep = RC linked Slow beep = Low battery threshold Fast beep = RTH or Altitude Hold are active
GPS Calibration of the GPS should be done outdoors. The green LED on the GPS sensor will normally start flashing after a few seconds. It typically takes another 1 to 2 minutes for 4 or more satellite signals to be acquired and start flashing the Green LED at the tail of the Sky Rider.
If any of the tail LED's do not light at all, check that the connectors on the 10 pin connector at the back of the LED board are properly seated. If any of the connectors are not fully seated, the LED's may not operate correctly.
