Many thanks there to Ian! Sorry for the delay in finishing up dear old Frederick - been having trouble with a winter bug and migraines lately but here he is at last!
I've crammed the whole base building into one installment so I'm afraid it is a bit 'wordy' but I hope the updated photos at the end will make up for that! (Sorry I couldn't get his legs in, the backdrop wasn't big enough!
Many years ago I was given a beautiful slice of Agate stone as seen in
Photo 1. It came with a little clear plastic supporting stand visible at the bottom of the stone but a little while after I managed to pick up a lovely octagonal wooden stand to display the piece on. I’m not exactly sure where I got it from, but I’m fairly certain it was from one of the Model Exhibitions held in the Guildhall down here in Plymouth. Anyway, after all those years I’m afraid Mr Agate has lost his plinth – I need it for Frederick (and it’s just the right size!).
Photo 2 shows the wooden plinth after a good dusting and a quick clean up with a damp cloth – and it needed it too!
The first task was to remove Frederick from his temporary base – another block of plain wood used to hold him steady for the various adding on procedures, pose him where I wanted him to stand and then mark the positions of his two metal rods coming out of his feet. From those marks I could then drill out the base to fit those same rods in again. I chose to do this with the bench press drill as shown in
Photo 3, (I’m not the most accurate at free-hand 90 degree hole drillings!)
With the holes drilled and cleaned out, the base was then covered in some of Mum’s cling-film, this would allow me to model the ground work, and do all the painting steps without worrying about messing up the surface of the wood. The basic ground build up was composed of
DAS Modelling Clay, an air drying material which I used for the sandbags in the Scramble diorama. This was a new pack, freshly opened as shown in
Photo 4. I sliced off about a half inch thick slab of the clay and using a piece of aluminium tubing, rolled the clay out into a sheet of around a quarter inch or 5mm thickness. (I must remember to get a rolling pin in the Poundshop, I’ll need that tube for something one day!)
A pair of cocktail sticks were inserted into the drilled peg holes in the base, and the sheet of clay was dropped over the top to lie flat on the cling film. The edges were then trimmed back with an old kitchen knife to leave the clay as shown in
Photo 5. The ‘flat’ clay effect was then removed with some very basic stippling accomplished with an old toothbrush as shown in
Photo 6. This is simply a case of ‘dabbing’ the bristles of the brush down into the clay with the minimum of force required to make an impression, push too hard and the brush will just embed itself and remove large clods of clay! Once the stippling was done, the two cocktail sticks were removed temporarily so that I could take Frederick and gently push his feet with their brass pegs down into the holes to leave a pair of footprints in the clay, this would ensure that he would fit exactly back in position once the base was finished and would also stand ‘in’ the ground, not perched over the top of it! With the basic terrain texture complete, I went back to my store of
Woodland Scenics Talus (assorted rocks) and selected a few bits and pieces to represent the small stones that would be un-earthed by the medieval plough and/or weather out of the cultivated soil. These were pushed in to the clay surface and left overnight for the clay to air dry. The difference in colour between the fresh clay and the dried can be clearly seen in
Photos 7 and
8. The final preparation was completed by a good thick coat of
Admiralty Yellow Ochre acrylic paint as seen in
Photo 9. Any loose looking stones were removed first and carefully arranged around the base so I could relocate them back in their original positions later. After leaving the paint to dry overnight, the following evening the ground work was given a light wash with
Citadel Skaven Brown acrylic ink to bring out the textures and shadows as can be seen in
Photo 10. Frederick’s footprints are also more evident in this shot! After the depth-adding shadows, the next step was to add the lighter highlighting using a mixture of the Yellow Ochre and some
Revell matt White acrylic, drybrushed over the ground texture. Before doing that however, the missing stones were glued back into position with super glue gel and then the whole of the groundwork was drybrushed as one, blending the stones back into the overall soil colour as shown in
Photo 11. The final act for the ground was to add a subtle dusting of the
Carrs Mud powder to add the orangey brown tinges to the soil. The Carrs was originally bought for the Messines diorama and is still going strong! (
Photo 12)
The last essential part of the base work was the stalks of ripening oats to represent the fields over which part of the battle took place. To start off, I needed to create the leaves for the oat plants.
Photo 13 illustrates the beginning of my agricultural phase of the model with the first set of leaves being scissor-cut from a piece of yellow crepe paper. I hunted everywhere to find that crepe – the design for creating the oats was based partly on a site I came across on the web for making scale corn plants for doll scale farm houses. It was only after I began making up the plants that I discovered that I should have been after raffia NOT crepe! Still, this method worked really well so it didn’t matter in the end! Each oat stalk has three sets of leaves, smallest at the top just below the oat husks or seeds, each set at right angles to the one above. In order to make the actual oat stalks with the ‘ears’ of oat I went for the most natural looking material I could find – someone else had done all the work on designing this and I can’t better His work!
What I’m using is a species of wild grass – I haven’t a clue what the species name is, but I found this whilst on my walks to the bus stop up the hill when my back was ‘done in’ and I couldn’t ride my bike to my caring job. Along the grass verges were patches of this wild grass and as they turned a golden yellow in the summer the seeds looked just like miniature oats! I duly collected a few handfuls of the stuff, each one carefully selected for the best looking ‘heads’. The first batch didn’t go to plan however, I tried to preserve the grasses with diluted pva but all that did was to stick all the seed heads into one thick stem – not the ‘wispy’ oats blowing in the wind I wanted! I then sent off for an aerosol can of matt varnish and that (when sparingly applied) did the job and I ended up with sealed grass stems still looking wispy at the ends (see
Photo 15) Before the previously cut leaves were attached they first needed to be given a brushing over with neat pva glue as shown in
Photo 14. This was simply brushed over the crepe paper leaf with a stiff bristled brush and immediately after the application the bottom of the leaf was gently lifted up and the still tacky end rolled between the thumb and forefinger. This produces a tightly rolled ‘stem’ which is then used to attach the leaf to the natural grass stalk with more pva. (The rolling action to create the stem was discovered by pure accident – I was actually trying to get a sticky leaf off of my fingers at the time!)
As you can see in
Photo 15, some of the ‘ears’ did come loose during the sticking process but these were saved up and applied to the base groundwork for extra effect. At the time Frederick was completed for the competion (before I blew it!) he appeared as in
Photo 16. Afterwards however I discovered that oat plants are not as tall as I thought – on average about four to five feet, not the six to seven I had modelled them at! I therefore trimmed them down a bit and, while I was at it also decided to airbrush the lower halves of the plants to give them back a little more green colour. This would also have the effect of making them two toned – green at the bottom and ripening yellow at the top which looked much better as you can see in
Photo 17. I would have loved to have put in twice the number of oat stalks to give the impression of Frederick standing and fighting through a dense field of crops, the trouble was, the more oats the less Frederick can be seen! In the end, I stopped at four as a compromise. The last act I needed to do to put Frederick in the middle of his most famous battle was to ‘bloody’ him up a bit. Originally I was going to put a lot of blood spatter over his torso too which would probably have been more realistic but just as with the oats, its possible to get carried away so for best effect I’ve given him a bloodied sword and some ‘arterial spray’ over his shield. For the blood, I popped into the local
Games Workshop store (they’re a pretty bloodthirsty lot!
) and found a pot of acrylic called “
Blood for the Blood God” – and you can’t get much bloodier than that! This is a really nice paint to simulate blood and gore which stays looking wet after it has actually dried as you can see in
Photo 18. The blood on the sword blade was applied with a small fine brush but for the shield I first experimented on a scrap of white card and found that by dipping a short, stiff bristled brush just into the paint and then carefully ‘aiming’ the brush at the card and using my thumb to pull the bristles back I could literally ‘flick’ the paint over to the card to create a realistic ‘blood spatter’ effect (yes, I watched the original CSI series too!)
Once I’d got the hang of it, I used to same technique to flick the blood paint across the top left quarter of Frederick’s shield after first placing some paper tissue behind the shield so I didn’t spray Frederick as well. With the oats shortened and greened up a little, and the blood work done the final appearance of Frederick the Victorious was as shown in
Photo 19.
I can honestly say I’ve enjoyed this build more than most others – I’ve learnt or developed so many more skills and techniques on Frederick, from working in leather and silver leafing to basic metalworking and even ‘horticulture’ and I would love to get back into this 1/12th scale for future projects.
I hope you have enjoyed reading this medieval epic as much as I enjoyed building it and to leave you all as I start getting to grips with this year’s project, here’s a little series of photos to end up with, showing my favourite Count of the Palatinate in the thick of battle!
So until “
A Litter of Pups” is ready to start posting
, Happy Modelling to you All!
Robin.
First wooden ship:
The Grimsby 12 Gun 'Frigate' by Constructo Second:
Bounty DelPrado Part Works Third:
HMS Victory DelPrado Part Works 1/100 scale
