 Rank: Elite     Groups: Registered
Joined: 26/04/2014 Posts: 1,503 Points: 4,421 Location: Essex
I have just fitted the front bearings and wheels onto the axles and the bearings on 1 of the wheels are quite a loose fit in the wheel. So when the wheel is bolted onto the axle it is quite wobbly. Has anyone else come across this? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046 Senna lotus 97t complete https://forum.deagostini...id.googlequicksearchbox|utmccn=(referral)|utmcmd=referral|utmcct=/&__utmv=-&__utmk=37308643
As you paying catch up, its always a good idea to first check the previous discussions http://forum.model-space...aspx?g=posts&t=7700
The upshot is (and after many have now completd and run their RB7), there has not been a problem as a result of a slight sloppy fit of the wheel bearings.
Ok. Thanks Mr T. I have read it now and I might try the ptfe route and see how that goes. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
PTFE tape often works, but ensure that it's even otherwise it will create wheel bounce.
Joined: 16/06/2014 Posts: 65 Points: 188 Location: Austin, USA
I ave found the loose bearings not to be a problem at all when running the car. Everything works great.
