Joined: 27/04/2016 Posts: 18 Points: 81 Location: Upholland
I have just received my replacement parts only to find them damaged inside. File Attachment(s): 1.bmp (1,407kb) downloaded 59 time(s).
Looks like the box has been cut open with a knife which has also cut into the content packs. Have flagged this with despatch.
Thanks, Tom
Is it ok to open the other packs?
They have dents in the outer packs but can't tell if the items have dents in them without opening them.
Clearly the 1 pack is scratched, but the other 2 need opening to check fully.
Didn't want to open them without contacting you first.
Those that are undamaged you can use, please let me know which Stage packs have been damaged?
The dents in the outer packages do not appear to have reached the items inside.
The only issue is with RB7-091.
Ian
Hi
Any comments from dispatch regarding this item?
