Rank: Pro Groups: Registered
Joined: 03/02/2015 Posts: 457 Points: 1,389 Location: Crawley, W.Sx, UK
Morning Trev. Thank you. I'm itching to complete now that it is taking shape. I've been quite indecisive about which way to go and what to do to make it look as good as it can but I think the route I have taken is paying off even though a little more time and effort is required. Has anyone actually ever finished the Spitfire build-I haven't seen any photos-it would be nice to see some completed kits. Have a restful Sunday. Regards. Alan ALW attached the following image(s):
ALW wrote:Morning Trev.
Thank you.
Regards.
Alan Ailerons complete!
Joined: 13/02/2011 Posts: 2,227 Points: 6,801 Location: UK
Hi Alan, Ailerons are looking very smart nice job and I am very pleased your build is going the way you have planed as some times we have the opposite, as for a finished Spit build I am sure the Spanish guy's have built it may be Mr T knows more. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev. Thank you. I've just painted the removable panel attached pic, (which I will be securing with micro screws) but I've noticed a slight blemish on the paintwork so will correct that tomorrow when its dry. Just ordered some rivets and panel lines ready for the fuselage which is nearly finished. I have been waiting for some extra plates which arrived today so will get on with that tomorrow. Once these panels are fitted it will just be a case of applying the rivets and paint! Well hopefully. Then focus on the wing-a few tidy up bits and that will nearly be it. Hows your build going? Regards Alan ALW attached the following image(s):
Looking great Alan, very neat and tidy work..
Thank you Alan
I'll hopefully have some more photos tomorrow.
Regards.
ALW wrote:Has anyone actually ever finished the Spitfire build-I haven't seen any photos-it would be nice to see some completed kits.
I think most are still heading towards the end. The operable end result can be seen at the end of the official build video https://m.youtube.com/watch?v=tzWLG_5Ldrg
HI Alan. great looking build, very well done. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Ian Thank you. I'm really enjoying this part of the build-seeing it all come together and nearly finished! Regards Alan ALW attached the following image(s):
Cockpit door fitted. As you can see from my recent photos I have started painting the camouflage, but ran out of the dark green so duly ordered some more, continued painting, only to discover the second can I bought was a considerably lighter shade of green! Same manufacturer, same codes-I would maybe accept a subtle difference but it is very noticeable. I've asked for some technical advice as I have never experienced this before. Never mind! The wing is nearly finished, will post a picture once I have primed it. Regards to all Alan PS. Please don't take too much notice of the 'messy' look of the fuselage, it's more work in progress! ALW attached the following image(s):
First coat of primer.Checking for discrepancies. Tiny amount of adhesive spillage, will rectify and carry on! ALW attached the following image(s):
Received my panel strips and rivets today. They are a real bonus as they will allow me to enhance the aesthetics of the finished model.
I have 1 more plate to fit, LEDs fitted now, all the other parts are painted ready to be fitted as soon as I have tidied up the fuselage and applied the rivets.
Paint problem. I bought two identical tins of aerosol paint dark green 163 but if you look at the picture you'll see the difference in shade! Looks like I've got to do a re-spray once Humbrol get back to me. Good job I didn't do the whole model! ALW attached the following image(s):
Before and after priming! Ran out of paint again so got to wait now. I can see the finishing line! Regards to all Alan ALW attached the following image(s):
Although I haven't finished this build yet I thought I would post a list of materials I used to help anyone who needs it!
It's been a bit trial and error with adhesives etc so here is what I used.
Super glue precision max and gel Gripfill (excellent gap filling adhesive, came in very handy in a couple of places) U-pol extra, polyester aluminium filler Ronseal woodfiller (again excellent product, quick dry, easy sand. Evo-stick Multi-Purpose Time bond, contact adhesive. Hycote etch primer
Cockpit and airframe paint-colour RAL 6019, pastel green, satin, made by Mr aerosol.These are custom filled,in my case suitable for wood.
UHU white tac Humbrol dark green 163, satin Humbrol mid sea grey 165, satin (for the underside) Humbrol sea grey, matt (for topside)
Rivet and panel lines from Mick reeves, these are excellent!
Not much to say about the build itself, it had some awkward to fit parts, and I didnt like the look of the pin heads showing on the fuselage so I filed them down to a point where they will keep the panels in place but cant be seen.
I'm still toying with the idea of doing the same to the wing but that's going to be really involved (I haven't pinned the underside panels), I'm going to paint the wings first and make a decision then whether or not to file the pins down at that point.
Hope this helps someone. I have received a lot of help, advice, and suggestions from some very knowledgeable people on this forum of which I am very grateful,so wanted to give a bit back.
Regards to all
Another photo. ALW attached the following image(s):
Nice work Alan, looking very good and not too far to go now until it's finished as you say? Shame about the mismatched paint but I'm sure you'll end up with a good result - well done!!
Kev
Hi Kev
Thanks and yes the paint's holding me up now. I bought the original tin direct from Humbrol too!
I'm looking forward to the finishing touches, and really looking forward to seeing the undercarriage, lights and prop working-I don't think I'll ever grow up!
Dry fit canopy whilst waiting for my paint! And second coat of primer ready for the third! ALW attached the following image(s):
That's a superb photo Alan, from a great angle and nice to see inside a fully fitted cockpit, which I think you've done a great job of by the way. The windshield looks like it will fit very well without need for much filler when you come to glue it in place permanently and you have achieved a nice curve to the canopy framework - well done!!
Kev
