Joined: 13/02/2011 Posts: 2,241 Points: 6,843 Location: East Sussex
Hi Shipmates, Well i have just joined this forum after a long time login on and watching you all build your Victory's,and you all are building to a very high standard i just hope mine will be half as good.My build is at about issue 23/24 and have still to plank the hull which will be a task.Just getting around to loading up my pic's for you to compare with,there is only a few at the moment but more will follow.I have been building plastic kits for years but this is something else. Regards tf64. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
welcome tf64..look forward to your build pics.its a tricky one but that is just my opinion cause its my first major wood build and i have learnt alot from others and also my mistakes..benny cheers benny
Joined: 30/01/2011 Posts: 865 Points: 2,410 Location: Cambs
Hello there, I totally agree with Benny, its difficult, I make mistakes, but hey it's good fun. Come on you Jimmies
Welcome to the forum tf64 and look forward to seeing your build photos
tf64 wrote:Hi Shipmates, Well i have just joined this forum after a long time login on and watching you all build your Victory's,and you all are building to a very high standard i just hope mine will be half as good.My build is at about issue 23/24 and have still to plank the hull which will be a task.Just getting around to loading up my pic's for you to compare with,there is only a few at the moment but more will follow.I have been building plastic kits for years but this is something else.
Regards tf64. hi..one good thing is your 20 issues behind so all the mistakes have been made and resolved so you have all the info you need right here.i think at some stage us newbies av rushed a little,i still do so take it easy and take time out to think a little...cheers benny cheers benny
