Drillbits Options
StefanDV
#1 Posted : 02 March 2011 17:54:57
I was under the impression (from the pictures) that we whould receive one of those hand-drill jobbies with the 'toolkit' - this turned out to be a mistake on my part.
Anyone know where in SA one can get one of the hand drills (sorry I can't remember the correct term for it now)
I have a Dremel with the drill stand and a chuck attachment so if I can source mirco drillbits for a reasonable price, could it be an option?
willie
#2 Posted : 02 March 2011 18:16:28
if its the same tool kit we get in the uk you shoud have the drill plus a drill bit drill looks like a handle with a twisted steam as for dremel a lot of modlers use them and a little tip cut the head of a pin and it will drill wood dress making ones are the best 0.8mm dia
#3 Posted : 02 March 2011 19:27:21
The drill is called an Archimedes drill...I have one and had it for a number of years, damn handy drill to have too. Have you tried sourcing a drill and drill bits on google or E.Bay...shouldn't be too difficult to pick up one...hope this helps???
BigGrin
StefanDV
#4 Posted : 04 March 2011 20:13:22
Thanks Gents!
The kit supplied in SA does not have the drill, even though the earlier pictures of the kit showed one.
Does one just cut a notch in the head of the dressmakers pin?
I'll use the dremel, even though I suspect the hand drill will give one more control.
Grizzly
#5 Posted : 04 March 2011 20:32:12
I got the tool kit supplied and it did contain a archemedies drill.
Not a very good one but one never the less.
willie
#6 Posted : 04 March 2011 21:59:38
StefanDV wrote:
Thanks Gents!
just cut the head stright off with a pair of snips, the cutting with snips tapers the point and that cause it to drill ,eg >
Sietse
#7 Posted : 05 March 2011 08:23:13
I received my tool kit including the hand drill. It’s not the best of quality but remember the tool kit it’s for free.
Albatross, build in 1982 from plans.
Hms Bounty, build in 1987 from plans.
Duyfken,build in 1991 from plans
Oosterland, build in 1998 from plans
2010 Hms Victory kit from Deagostini
In the meantime.
2011 Building MFV 1963 fishing trawler from plan.
Atholm
#8 Posted : 05 March 2011 08:46:09
Hi StefanDV
See my post on the drill supplied
http://forum.model-space...aspx?g=posts&t=1971
I received the drill yesterday after ordering it on 17/2/11. Very happy with quality.
Cost including air delivery $8.39
Athol
Gan_Javi
#9 Posted : 11 March 2011 18:32:17
Hi, if you haven't found the bits, I know of a place.
In cape town (montague gardens to be exact) there is a hobby shop called "Clowns Hobbies". They stock artesania Latina products, including a 5 drill bit set (0.5mm, 0.75mm, 1mm, 1.5mm, 2mm I think). They are just before the Trade Centre in Koeberg Road. Hope that helps =)
StefanDV
#10 Posted : 12 March 2011 14:47:06
Great, thanks Francois!
Go you know which exact sizes do we need for this model? (some places stock decimal bits (0.5mm etc) and then one also find some strange sizes
(60,80 etc))
willie
#11 Posted : 12 March 2011 15:25:55
(60,80 etc))
------------- these are number drills some times called wire guage drills some times the victory instructions refere to them you will find plenty of conversion charts on the net sizes used on the model so fer is 0.7,0.8 ,1.0and 1.5mm
StefanDV
#12 Posted : 14 March 2011 09:58:16
Thanks Willie,
So far (up to issue 16 only and still waiting for issue 14) I've only used a 0.5mm, 1mm and a snipped sewing needle. (Shown below)
Guest (8)
This page was generated in 0.120 seconds.
