Rank: Super-Elite Groups: Registered, Moderator, Tech Support, Technical Support, Forum Support Team, Forum Support USA, Global Forum Support, Global Forum Support Team Joined: 17/12/2013 Posts: 3,983 Points: 11,974 Location: NY, USA
Thats a cracking build Tony.
Rank: Elite Groups: Unapproved
Coming together nicely, Tony.
Really nice work, can see the care and attention you're putting into this..... Look forward to seeing your next update.... Regards Alan
Hi Tony. fantastic looking build. very well done. look forward to seeing your next update. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Rank: Master Groups: Registered
Hi Tony, Enjoying your build. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Rank: Administration Groups: Registered, Forum Support Team, Administrators, Global Forum Support Team, Moderator, Official Builds Joined: 09/11/2012 Posts: 7,946 Points: 23,024 Location: East midlands
Very nice tidy work. Well done Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 09/08/2012 Posts: 59 Points: 163 Location: Darwin
Hello everyone, How are things? well after about two years in storage I decided to pull the stored model out and complete it, Yeah yeah I know, life and work gets in the way. I was so close to finishing it but this time i'm determined.I started with episode 29 or 149 depending on which way you look at it, finished the bulwarks, timberheads, pin rails and kevels and also made the main mast pin rails, I didnt paint the belaying pins, personal choice really. I also started 150 and attached the wriggles and fenders and did the mouldings and scrolls, Used a filed down toothpick for the circular scrolls which is hard to do and had issues with the mouldings as the curves kept breaking hence mine look straighter.I painted the entry ports then used a gold coloured texture to enhance the mouldings, the result was a lot neater than painting them on, Im extremely pleased with the end result, Im away on holidays soon so i should be able to finish everything else off when I get back. Im currently working on the side ladders but I should have some more photos for you on my next installment. PS I suck at sewing so I have to thank my other half for her exploits in doing the rolled hammocks, she has done about half of them. Talk again soon and apologies for my slackness Cheers Tigershark Tigershark attached the following image(s): Cheers Tony
Current Build
HMS Victory, HMS Victory Cross Section
Good to see you back. Life has a habit of getting in the way of what you enjoy doing. Will be following to the finish, good luck. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Great to see you back and posting on this, all looking great. Look forward to seeing more.... Regards Alan
Good to see back on this, it's looking great.
Welcome back look forward to seeing this continue. Al
Rank: Superelite Groups: Registered
You’re right, those mouldings do look really good! You are right to be proud of how it is turning out
Looking good and very nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 11/11/2009 Posts: 3,432 Points: 10,280 Location: Bâe Colwyn, Wales
Looking very nice Tiger. Doing a great job. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Joined: 30/09/2018 Posts: 36 Points: 98 Location: California
happy holidays, hope to see more updates afterwards NOW - Building SWIFT 1805
long term goal "USS Constitution" completed "Fair a Frame" by Model Shipways
fantastic looking build Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
