 Rank: Pro  Groups: Registered
Joined: 23/03/2010 Posts: 202 Points: 528 Location: Bedfordshire
as i have decided to double plank the top half of the hull in a lighter color than the bottom half i was going to make the Wale's the same dark color as the bottom half the problem  i have come up with is the lower wale being the same color as the lower hull will blend in with it i made the dividing line where the color changes on the hull 1 plank below the lower gun ports which works out about half way up the wale  would it look stupid if i was to lower the color separation line 3 planks lower? so as i can get the definition of the Wales to stand out i just hope i have explained it well enough
as you are changing the colours it is entirly your choice what rocks your boat(pun intended)you will have to experiment at what level you want to change the colour,if it help take a look at my build you can see the colours on that.and judge for yourself.any chance of some pics? Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
karl1113 wrote:as you are changing the colours it is entirly your choice what rocks your boat(pun intended)you will have to experiment at what level you want to change the colour,if it help take a look at my build you can see the colours on that.and judge for yourself.any chance of some pics? hi Karl all my photos are on photobucket Photobucket
 the colouring looks ok,are you going to paint? Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
No paint if i can get away with it
