Hi Gil. Great start to your cross section. Look forward to seeing your progress. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Joined: 10/10/2010 Posts: 678 Points: 2,094 Location: Dorset
Issue 124 begins the outer planking. The rib framework is very fragile at this stage, I have taped the fret across the top as suggested to help keep the structure square. In order to provide a stable base whilst adding the lower planks I have routed a channel in a piece of 3X2 to accommodate the keelson. I will then carefully clamp the framework to the "jig" and add the lower planks to both sides of the hull. GilShapley attached the following image(s): Current Build:- [color=blue]Stash Avro Lancaster (Full Kit)plus some extra issues I picked up at a good price [color=blue]Built:- Norman Catapult by Mantua,Roman Catapult by Mantua,HMS Victory,HMS Victory XSection,Focker DB1,Bismark,English Carronade Titanic Lifeboat,American Civil War Gatling,Hummer,Sopwith Camel F1,Occre Jupiter ,OcCre Wagon, Latina Arab Dhow, Eaglemass Orrery OcCre Rogers 119 [color=red][color=red]RB7,OcCre Missippi River Boat, Model Airways Fokker DR1 OcCre London L>C>C 106 Ugears Scrambler, Ugears Hexapod Explorer UGears Off-Road Vehicle
Nice work, certainly looks very delicate. I still have this one to build Steve
Issue 124 - Contd Planking - added up to the top of ribs 3 and 7 (The bottom of the lower guns ports) Have done some sanding of the edges of the planking but will need to finish this part. The frame is fragile at the start of this part of the build and as suggested I taped one of the frets across the top to add support. In addition I also used the supplied rib spacers as additional support for the ribs as I added the planking, moving them up the ribs as the planking progressed. This not only added some additional support but also made sure the rib spacing was maintained. One near disaster, I left the partially planked frame in the conservatory (my temporary workshop). Upon my return I found that the tape across the top of the frame had come unstuck and the frame had opened up like a flower in the sunshine. A few minutes of panic then I replaced the supporting fret back onto the frame and held it in place with elastic bands which have pulled the framework back into shape GilShapley attached the following image(s): Current Build:- [color=blue]Stash Avro Lancaster (Full Kit)plus some extra issues I picked up at a good price [color=blue]Built:- Norman Catapult by Mantua,Roman Catapult by Mantua,HMS Victory,HMS Victory XSection,Focker DB1,Bismark,English Carronade Titanic Lifeboat,American Civil War Gatling,Hummer,Sopwith Camel F1,Occre Jupiter ,OcCre Wagon, Latina Arab Dhow, Eaglemass Orrery OcCre Rogers 119 [color=red][color=red]RB7,OcCre Missippi River Boat, Model Airways Fokker DR1 OcCre London L>C>C 106 Ugears Scrambler, Ugears Hexapod Explorer UGears Off-Road Vehicle
Joined: 11/11/2009 Posts: 3,432 Points: 10,280 Location: Bâe Colwyn, Wales
Nice update Gil. Your doing a nice job of her. When you start planking around the gunports be mindful of the glue on the back of the planks. As there are some framing to install later that sit flush with the inside of the planks. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Good work on the neat planking, she's looking well Al
Rank: Administration Groups: Registered, Forum Support Team, Administrators, Global Forum Support Team, Moderator, Official Builds Joined: 09/11/2012 Posts: 7,963 Points: 23,078 Location: East midlands
Nice progress. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice job Gil looking forward to seeing your your next update Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Looking sweet, very nice work indeed.... Regards Alan
Good job with the planking Gill, it's look nice and neat It's really clever how they use the fret to add support to the frames, they sure to look delicate
Beautiful neat work on the planking there Gill Steve
Great job on the planking, she's coming along nicely. Graeme
As usual top notch work from Gil.Really enjoying watching this build my friend.
Many thanks for the positive feedback. I have nearly completed the internal planking in issue 125 ,pictures to follow shortly Current Build:- [color=blue]Stash Avro Lancaster (Full Kit)plus some extra issues I picked up at a good price [color=blue]Built:- Norman Catapult by Mantua,Roman Catapult by Mantua,HMS Victory,HMS Victory XSection,Focker DB1,Bismark,English Carronade Titanic Lifeboat,American Civil War Gatling,Hummer,Sopwith Camel F1,Occre Jupiter ,OcCre Wagon, Latina Arab Dhow, Eaglemass Orrery OcCre Rogers 119 [color=red][color=red]RB7,OcCre Missippi River Boat, Model Airways Fokker DR1 OcCre London L>C>C 106 Ugears Scrambler, Ugears Hexapod Explorer UGears Off-Road Vehicle
Whist waiting for the glue to harden before I sand the planks decided to make my own display stand. Will use the stand provided to support the model during construction but will display it on my the stand I have made. Used some pieces of Oak I had left over from some display cabinets I have previously made.I used the ply pieces provided for the stand as a template. I have not yet glued the pieces together in case there is a need to fine tune the size once the model is complete The piece of blue felt will be used to line the top edge of the stand to protect the painted hull GilShapley attached the following image(s): Current Build:- [color=blue]Stash Avro Lancaster (Full Kit)plus some extra issues I picked up at a good price [color=blue]Built:- Norman Catapult by Mantua,Roman Catapult by Mantua,HMS Victory,HMS Victory XSection,Focker DB1,Bismark,English Carronade Titanic Lifeboat,American Civil War Gatling,Hummer,Sopwith Camel F1,Occre Jupiter ,OcCre Wagon, Latina Arab Dhow, Eaglemass Orrery OcCre Rogers 119 [color=red][color=red]RB7,OcCre Missippi River Boat, Model Airways Fokker DR1 OcCre London L>C>C 106 Ugears Scrambler, Ugears Hexapod Explorer UGears Off-Road Vehicle
Very nicely done with the stand lovely job Gil Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
That's a great looking stand Gil and more robust than the original Al
Issue 126 now complete onto 127 Some more exterior planking and starting on the fittings with the mast step. Looking forward to getting stuck into the details of the interior of the various decks GilShapley attached the following image(s): Current Build:- [color=blue]Stash Avro Lancaster (Full Kit)plus some extra issues I picked up at a good price [color=blue]Built:- Norman Catapult by Mantua,Roman Catapult by Mantua,HMS Victory,HMS Victory XSection,Focker DB1,Bismark,English Carronade Titanic Lifeboat,American Civil War Gatling,Hummer,Sopwith Camel F1,Occre Jupiter ,OcCre Wagon, Latina Arab Dhow, Eaglemass Orrery OcCre Rogers 119 [color=red][color=red]RB7,OcCre Missippi River Boat, Model Airways Fokker DR1 OcCre London L>C>C 106 Ugears Scrambler, Ugears Hexapod Explorer UGears Off-Road Vehicle
Looking great Gil, love the build stand.... Regards Alan
