Nice work, the parts look really well detailed. Very impressive. Graeme
Rank: Pro Groups: Registered
Joined: 08/02/2015 Posts: 274 Points: 812 Location: Malmesbury
Looking great as always Regards Shaun Building-RC spitfire Build- titanic,Skyrider drone, solar system, T72 tank
Rank: Master Groups: Registered
Joined: 19/05/2015 Posts: 1,419 Points: 4,272 Location: Darmstadt, Germany
It only gets ever more tinier from here on out. 24: We detail what can now be identified as the control box for the air throttle and pitch control. Another instrument case is bent to shape.
Joined: 07/01/2015 Posts: 856 Points: 2,479 Location: Sevenoaks, UK
What is the size of this thing? Any images I post on my personal builds are free to be used and shared under Creative Commons Attribution license, which means you can do what you want with them, on the condition you mention I'm the author.
Happy building :-) http://www.model-space.com/gb/
The stuka itself is scaled in 1:16, so 70 cm long, 93 cm wide and 24 cm high. The control box above is a centimeter by one and a half. (see also here on the upper right http://forum.model-space...amp;m=225507#post225507 )
Excellent work on this Michael, looking great and some nicely detailed parts coming through. I can see you being sick of the sight of photo-etch and bending tools by the time this is completed!?
Kev
Hello Michael,
That would explain why so few of these are ever completed then?! Modelling is a fantastic hobby, but it has to be fun. Any prolonged periods of repetition will quickly lead to boredom, which is why so many of us start several builds at the same time, to give us a break from those monotonous stages. I wonder if Hachette realised that boredom would become a factor when building this model even though it's a fabulous idea to make it all out of brass?
Kev
Really nice work with that tiny etch
Think we'll nickname you the 'etchmaster'..... some great looking work... Regards Alan
Gandale wrote:Think we'll nickname you the 'etchmaster'.....
Alan Or the Brass Baron!
Rank: Administration Groups: Registered, Forum Support Team, Administrators, Global Forum Support Team, Moderator, Official Builds Joined: 09/11/2012 Posts: 7,963 Points: 23,078 Location: East midlands
[/quote] This was one of the major problems with this kit during its original run. The kit spends too much time on the same type of work without anything "different" in between. For now we have issues upon issues coming up where we keep folding, bending and glueing together increasingly tiny instruments with no end in sight and none of them getting installed. We end up with a collection of easily losable parts. Then the kit switches over to putting together the wings one spar at a time for dozens and dozens of issues. Meanwhile people started to wonder if there even were enough issues left to even finish the plane in any way. Finish it did indeed, but it was all done in the last three issues. Which opened a whole other can of worms, but we'll get there when we get there.[/quote] I`ve built this kit a coouple of stages further than this one and Greyhawk is right. You seem to spend endless hours putting bits of brass together and half the time not knowing what they are. Greyhawk will also find one thing a bit easier. I was working from the instructions, even though they were in German and had to translate them. As you will know Greyhawk has a slight advantage there. Good luck with the rest of your build, I`ll be following with interest, espescially when you get past the point I reached. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
I'll take "the Earl of Etchington". 25: More detail work on the small stuff, including the control box for the dive brake and the fuse box.
The Earl of Etchington... now I like that.... .. Another beautiful session from you.... great work.... Regards Alan
Yep I like the Earl of Etchington! Another fine update, I am sure it will all be worth it in the final stages.
26: More fiddly small stuff. Think I'm gonna do two more issues, reach a nice 20 % completion and then take a break and switch over to one of my wooden models.
Really nice work as always really enjoy seeing your progress with this build Regards Shaun Building-RC spitfire Build- titanic,Skyrider drone, solar system, T72 tank
27: Finished a radio set and started another one.
Lovely etch work and painting really like this build keep up the great work regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
