Great looking build. very well done. looks fantastic. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Rank: Pro Groups: Registered
Joined: 26/12/2012 Posts: 140 Points: 418 Location: Plymouth
Ok so been busy, started to add the detail of clothes, hair, jewellery and weapons. Loincloths was fairly easy with superfine milliput rolled out fine, some of the beads are rigging which is pre painted others are black milliput along with the hair. With regards to the hair this was black milliput, let it semi harden roll it out and platt it into strands, after doing this and letting it cure I have decided it needs to come off and be re done. The reason for this is it is not a high enough platt and looks too heavy and not what I was trying to achieve so will post agin once re done. godan61 attached the following image(s):
Joined: 07/01/2015 Posts: 856 Points: 2,479 Location: Sevenoaks, UK
This od beyond awesome, i wouldn't even know where to start and you seem to be close to finish line Any images I post on my personal builds are free to be used and shared under Creative Commons Attribution license, which means you can do what you want with them, on the condition you mention I'm the author.
Happy building :-) http://www.model-space.com/gb/
This just looks better everytime I see it nicely done. Al
Skilfully done, looks fab..... Regards Alan
started the base, easy and cheap way to create a nice effect. 1. 3/4 mdf kut into a rough shape and stacked 2. quick carving with a chisel and dremel sander 3. glue them together and seal with PVA glue 4. whilst the glue is still tacky spread quick dry polyfilla 5. use a wet sponge to smooth and crawl a texture 6. when dry using spray cans not an airbrush, base coat black, mist coat dark grey, mist coat light grey. This gives a lovely stone texture where you can now add some shadows and dry brush highlights and some some scenic effects. WHOLE PROCESS TOOK ABOUT 3 HOURS godan61 attached the following image(s):
Rank: Super-Elite Groups: Registered, Moderator, Tech Support, Technical Support, Forum Support Team, Forum Support USA, Global Forum Support, Global Forum Support Team Joined: 17/12/2013 Posts: 3,983 Points: 11,974 Location: NY, USA
That figure is amazing.You are a very skilled sculptor!
This is a very skilled build and a pleasure to watch.
Thanks for all the comments, this was a total departure and something new. I have always built kits or used a kit as a base model with regards to figures but has inspired me for my build entry for the year which I will start when this is finished. The bow is 3 bits of wood laminated together soaked in water, bent under pressure and left. It was then carved into shape with rigging used as the wrap and cross wrapped, painted black and dry brushed. The knife and scabbard shaped in milliput and carved. I have discovered that if you get the scale right doing this there is a lot that is achievable. If my plans for my next build are correct it will be about a foot long and 20 inches across. godan61 attached the following image(s):
So final steps of this test run, I have re done the hair achieving a tighter braid and rebuilding it in a deadlock style. I think this looks a lot better. The arrows are carved wood and milliput tips and feathers. Finally there is a collection of finished shots on out base which I placed infant of a printed backdrop of the floating mountains of pandora. Sorry couldn't resist it, hope you enjoy its been a new challenge but spurred me on for my build of the year. godan61 attached the following image(s):
I think your build looks amazing, and using that background just had to be done! Superb work and looking forward to seeing how you design next build!
You have done a fabulous job look forward to seeing your Ikran Al
A beautiful finished piece!! I'm really looking forward to seeing what you do with your non test piece for the build of the year. I thing it's going to be something quite special to watch based on this build
Thanks guys this has been an enjoyable departure from my normal builds and cost wise incredibly cheaper. Depending on how the ikran goes I may even build a viper wolf to go with it, got that sort of excited scared feeling .
Hi Godan. Fantastic end result. really well done. look forward to seeing your B.O.Y entry. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
