Coming along nicely, good job.
Nice update, mine came yesterday as well. It surprising how quickly it is taking shape. Mark
Rank: Pro Groups: Registered
Joined: 29/01/2017 Posts: 177 Points: 546 Location: Corby, UK
Thanks all. I'm really enjoying the build so far. Looking for something else to build along side this one. Maybe something to keep me a little bit more occupied. As the R2 build only takes about an hour a month. Any suggestions welcomed. Peter Completed - R2D2
Nice work, looking good.... .. As for something else to build, obviously this is down to your preference in the kind of models you like to build so why not take a look in the MS Shop, am sure you'll find something there to prick your desires.... Regards Alan
Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,051 Points: -13,308
i am building the r2 d2 as well, it really is well made, keep up the good work.
4 more issues came this week (13, 14, 15 & 16). I finally got time to build them. Issue 13 2 more dome parts to finish of the second layer. The 3 legs for the stand & a part of the metal frame for securing the second layer of the dome. Ritchie69 attached the following image(s): Completed - R2D2
Issue 14 Consists of another part of the metal ring frame & some leg detail. Ritchie69 attached the following image(s): Completed - R2D2
Issue 15 This issue has the final 2 parts to finish off the metal ring frame. Ritchie69 attached the following image(s): Completed - R2D2
Issue 16 In this issue there is more screws, nuts & bolts, and the first part of the 3rd layer of the dome. Ritchie69 attached the following image(s): Completed - R2D2
Nice update, it's amazing how quickly it's coming together. Regards Mark
Thanks Mark, Its enjoyable to build. The dome is quite heavy, hope the body has more weight or it will topple over Completed - R2D2
Nice update, certainly progressing nicely.... Regards Alan
Joined: 27/02/2016 Posts: 138 Points: 429 Location: milton keynes
good to see another astromech progressing Current builds: Eaglemoss DeLorean, Deagostini R2 D2 Build
Rank: Administration Groups: Registered, Forum Support Team, Administrators, Global Forum Support Team, Moderator, Official Builds Joined: 09/11/2012 Posts: 7,963 Points: 23,078 Location: East midlands
Looking good to date and growing rapidly. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice work, coming together and starting to look like R2.
Taking shape now Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Ritchie69 wrote:Thanks Mark, Its enjoyable to build. The dome is quite heavy, hope the body has more weight or it will topple over It looks very well designed so i am sure they will have the weights well balanced. It has to have batteries at a later stage so these may add to the base weight making it nice and stable. Happy Modelling
It's that time of the month again. The next 4 issues arrived. So I got straight down to building. Issue 17 Not much to do here, just another part of the dome frame to build. 2 wires to be used later. Ritchie69 attached the following image(s): Completed - R2D2
Issue 18 A bit more to assemble here, 2 more parts of the dome frame, and the microphone Ritchie69 attached the following image(s): Completed - R2D2
