Rank: Pro Groups: Registered
Joined: 29/01/2017 Posts: 177 Points: 546 Location: Corby, UK
Issue 19 This has to the most mind blowing issue so far. Only 2 leg details to insert. Ritchie69 attached the following image(s): Completed - R2D2
Issue 20 Only 1 dome frame to attach. The right leg sensor and ankle plate are for later. Ritchie69 attached the following image(s): Completed - R2D2
All in all this build is coming on nicely. So far the whole structure is very well built and the parts are not too flimsy. It is also getting quite heavy. The build is a little slow just now, but hopping that it picks up soon with all the parts not being used building up. Peter Completed - R2D2
Joined: 22/02/2017 Posts: 155 Points: 474 Location: Ireland
Nice progress so far Peter. Graham I was drowning my sorrows. But my sorrows they'd learned to swim.
Nice job and you're right, it starting to get some weight about it.
Looking good, well done.... Regards Alan
Looking good Peter, it's certainly taking shape. Regards Mark
Joined: 16/04/2011 Posts: 328 Points: 998 Location: Anglesey
Nice to see some good progress. Some issue's just don't make sense (I will be getting to that exciting issue soon) but I guess that how they drag it out over 2 years Darren
Have an AWSOME day and may the Force be with you always 😉 Building: Millennium Falcon https://forum.model-spac...sts&t=14381&p=7 - Building: BTTF Delorean - Building: Dom's Dodge Charger - Building : X-Wing https://forum.model-spac...aspx?g=posts&t=34899
Thanks all I suppose your right Darren, it's there way of stretching out the issues for the 2 years Roll on when there is more than just about 20 minutes of build per month. It takes me longer to take the photos and post an update. Peter Completed - R2D2
If R2D2 does everything what deagostini says then 2 years and £900 will be worth it. Everything time I look at R2D2 dome I get giddy 😀 Darren
Here we go with this months build. Issue 21 Here we will be securing the leg support to the leg. Then adding the first part of the wheel support. The inside leg cover will be for later and more screws as well. Ritchie69 attached the following image(s): Completed - R2D2
Issue 22 Just putting together more lights for the dome. Ritchie69 attached the following image(s): Completed - R2D2
Issue 23 Only 1 part of the dome to attach. The rest is for later. Ritchie69 attached the following image(s): Completed - R2D2
Issue 24 Only the wheel to start putting together. And more screws for later. Ritchie69 attached the following image(s): Completed - R2D2
Coming along nicely, starting to take shape.
Nice update, really taking shape now. Mark
Finally got round to this months build, it's been a busy week. I became a grand dad for the first time. My daughter gave birth to lovely little boy. So the build. Issue 25 The last piece of the dome frame fitted. And a couple of parts of the support for fitting later. Ritchie69 attached the following image(s): Completed - R2D2
Issue 26 Attached the wheel frame/surround with bearing and slotting in the wheel. Ritchie69 attached the following image(s): Completed - R2D2
Issue 27 The start of the projector. Circuit board fitted, now having to wait until next months issue 29 to test it Ritchie69 attached the following image(s): Completed - R2D2
