Rank: Pro Groups: Registered
Joined: 29/01/2017 Posts: 177 Points: 546 Location: Corby, UK
Issue 64b Attaching previous parts to the dome. Ritchie69 attached the following image(s): Completed - R2D2
Coming on very nicely, it is amazing how heavy the dome is now. Mark
Thanks Mark. I have to agree the dome is very heavy. Peter Completed - R2D2
Rank: Administration Groups: Registered, Forum Support Team, Administrators, Global Forum Support Team, Moderator, Official Builds Joined: 09/11/2012 Posts: 7,951 Points: 23,039 Location: East midlands
Really starting to look the part. Well done. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice work, looking good.
It's that time of the month again, the next 4 issue updates. Issue 65In this issue we get the projector lens, some dome details and cable clips. Ritchie69 attached the following image(s): Completed - R2D2
Issue 66We get the distribution board with mounting plate and dome fixings in this issue. Ritchie69 attached the following image(s): Completed - R2D2
Issue 67We start in the internal frame of the body . We have the bottom supports & plates. Ritchie69 attached the following image(s): Completed - R2D2
Issue 68This is the start of the outside of the body. We get a body panel, some body details and part of the shoulder fitting. Ritchie69 attached the following image(s): Completed - R2D2
Looking good and coming together nicely Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice work, coming along nicely.
Looking good, great update. Mark
Thanks all. Peter Completed - R2D2
That`s all looking very good. Well done Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Cheers Derek. Peter Completed - R2D2
It's that time of the month again. The next 4 issues we will be building will be for R2's body. Issue 69Frame parts Ritchie69 attached the following image(s): Completed - R2D2
Issue 70Back body panel & details. Ritchie69 attached the following image(s): Completed - R2D2
Issue 71More parts for the internal body frame. Ritchie69 attached the following image(s): Completed - R2D2
Issue 72Loud speaker for the back body panel. Ritchie69 attached the following image(s): Completed - R2D2
Nice work, coming on very nicely. I have noticed you have one of the frames the wrong way round. I have posted a picture of yours, and ringed the part that needs to be turned upside down to mirror the opposite side. You will need to do this as when you place the rods on the next stage they will not align. Mark Markwarren attached the following image(s):
