Joined: 11/12/2017 Posts: 34 Points: 108 Location: Canada
Stage 7 complete DonB attached the following image(s):
magpie1832 wrote:Very nice work. Looks really good, one tip for you.
Try to keep the spacer/support at the top of the frames in place whenever your not working on her as it tends to open up slightly over time. Then when you come to put the upper deck beams in place the gap is too wide.
Chris thanks for the tip Chris!!! It was already starting to spread. Hope I caught it in time.
Nice job looking really good Keepnthe pics coming Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Looking very tidy, great update. Mark
Sage 9 Complete. Interesting couple of stages. In stage 8 there was a step omitted from the printed manual that was in the video on You Tube as well as the Official Build Diary. The step which involved cutting the 1X6 MM plank to fit around the deck supports in not there in the printed manual. Good thing I keep checking all three resources. Also, the construction of the false keel is in both stage 8 and 9 in the manual. Interesting... DonB attached the following image(s):
Nice work, taking shape nicely now. Mark
Very nice progress, looking good.... Regards Alan
stage 10 done. Working with the oak veneer was "so much fun". For trimming pieces to fit I found that a scalpel worked better than an hobby knife. Had to be very careful sanding - not a lot of thickness to work with. DonB attached the following image(s):
Rank: Administration Groups: Registered, Forum Support Team, Administrators, Global Forum Support Team, Moderator, Official Builds Joined: 09/11/2012 Posts: 7,963 Points: 23,078 Location: East midlands
Looking good and progressing nicely. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Looking good and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 11/11/2009 Posts: 3,432 Points: 10,280 Location: Bâe Colwyn, Wales
looking very nice. Lovely job on the planks.
Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Nice work, coming on very nicely. Mark
Looking very nice indeed Don, well done.... Regards Alan
A good looking and tidy build Don Al
Stage 11 done. I think this stage shows the most progress so far. DonB attached the following image(s):
And very nice looking progress too.... Regards Alan
Coming on very nicely, keep up the good work. I am looking at building this kit soon, something very different for me and out of my comfort zone, so it is great to see your progression. Mark
Very nice progress. your doing a great job. Its a great kit tobuild.
Markwarren wrote:Coming on very nicely, keep up the good work. I am looking at building this kit soon, something very different for me and out of my comfort zone, so it is great to see your progression. Mark Thanks Mark. This is new to me as well and is lots of fun. If I can offer one peice of advice that is to read the manual carefully and watch the video diary on Youtube.com. Sometimes the manual misses things.
Stage 12 done. This one was interesting. I don't know what I did but somehow I didn't have enough 2X3 mm wood to complete the grating frames so I had to build one frame out of laminated 1X3. Then, not paying attention to detail, I glued the brad gratings in wrong and had to rip them out and re-glue them. DonB attached the following image(s):
