I did not follow the instructions, of course, but on the Transom there are 4 notches that I should have cut away the planking strips. I covered them with the walnut strips and I am unable to locate them now. Could someone please send me the measurements of the locations, If possible I will measure from the top of the stern gun port edge up to the notches. Thank you in advance for any help, Frank frank1964 attached the following image(s):
If you measure down from the top of the radius down, the measurements are to the top of each notch.
Hope this helps you, and good luck with the rest of your build.
Chrismagpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Yes, that helped a great deal chris. Thank you for taking the time to answer.
Frank
