Making good progress there Gray, nicely done.... Regards Alan
Another good update Gray exhaust looks sweet. Al
Rank: Superelite Groups: Registered
Thanks for looking in again, guys In Pack 5, we assemble the instrument panel and radiator. We also receive the airbox top and cable guides for use in a later stage. CaptnBirdseye attached the following image(s):
Nicely done Gray, making really nice progress.... Regards Alan
Looking good Grey and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Coming along a treat Gray Al
Thanks for the comments guys On with the build. Stage 6 sees the construction of the airbox, and cylinder block. This engine is going to look a doozey CaptnBirdseye attached the following image(s):
Stage 7 sees assembly of oil system parts, the engine block and plates, the crank case and crank case cover. There are a lot of images here, i think i might have got a bit 'snap happy' . This is as much as i can do now, as awaiting further stages. CaptnBirdseye attached the following image(s):
Hi coming along well there,looks nice engine.cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Great news-been told that next stage should be available soon So the build will continue shortly Cheers Gray
In Pack 8 we build up the gearshift bracket, the oil sump, oil sump drain, engine details and clutch case. For those of you who are wondering (as i did), the pinion provided in Stage 29 needs to be stored away as it is not used until Pack 23 . Everything went together relatively easily, with no glue needed for the oil sump lenses. Here is Stage 28: CaptnBirdseye attached the following image(s):
Stage 29: CaptnBirdseye attached the following image(s):
And Stage 30, which completes Pack 8: CaptnBirdseye attached the following image(s):
Have been told by Customer Services that there is a delay on Pack 9! Apparently, held up in 'customs' Hopefully not long now then
Looking good Gray, another very nice update that's beautifully presented..... Very well done... Regards Alan
Great work Gray, looking excellent. Mark
Rank: Pro Groups: Registered
Joined: 11/03/2010 Posts: 234 Points: 734 Location: Whelpley Hill, Chesham
Looking good Gray, it just gets heavier and heavier, this model will weigh a ton when it's finished. Nice presentation. Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Adapt, improvise, overcome.
Thank you all for lookin in guys Alec, you're right there about it's weight! Might need to re-inforce my shelving
Rank: Super-Elite Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 4,215 Points: 12,790 Location: ipswich
It's looking seriously impressive. It's going to be a biggie.
