Joined: 08/08/2018 Posts: 8 Points: 27 Location: Minnesota
I'm back after some time off from buying a house. With the shut down, I've picked the ship up again! Got it all faired and laid down the first three rows of planks. A bit rough, but I expect I will improve. Thought I would post some photos for your perusal. If anything appears way out of shape, please let me know before I get too far into it. ~ Burt Brutis attached the following image(s): ~ Burt
Rank: Master Groups: Registered
Joined: 21/04/2011 Posts: 1,039 Points: 3,140 Location: Buckinghamshire
Hi Burt, Welcome back to the forum. Like many others, there is time for us to spend modelling this wonderful ship. Everything looks fine at the moment but do make sure that you chamfer the edges of the planking and taper them, as per the instructions. It is too easy to end up with “clinkering” and large gaps appearing. Trial fitting is worth the effort. Good luck and enjoy. Take your time and I’m sure you’ll produce a great model. CHRIS
Good to see you back with us Burt.. Everything looks good to me, coming along very nicely..... Regards Alan
Rank: Pro Groups: Registered
Joined: 26/06/2013 Posts: 174 Points: 490 Location: Lancaster, PA
Greetings, Welcome back. I too have returned from a long break on this build. I will enjoy watching your Victory take shape. Christopher Current builds: HMS Victory Black Pearl
Builds on hold: Millennum Falcon USS Constellation
Future Builds: Hanse Kogge (14th C) Mary Rose (16th C)
Small update. I've got the next three rows of planking installed and the gun ports cut on both side. As expected, the last 3 rows fit better than the first. ~ Burt Brutis attached the following image(s): ~ Burt
Looking good, looks as if that will all sand down very nicely..... Regards Alan
That's looking neat and tidy, Burt. Keep it going. Chris
Greetings, Looking good. I remember that stage. Keep up the good work. Christopher Current builds: HMS Victory Black Pearl
